Android: Neutron Music Player
Feb 27, 2024 at 9:58 AM Post #1,336 of 1,375
Is there now a way, to prevent Neutron from starting, as soon as you activate Bluetooth?
Yes. Connection and Controls --> Play if output attached [gear icon]
Feb 27, 2024 at 9:29 PM Post #1,337 of 1,375
Does neutron player links with tidal like HiByMusic or uapp?
Feb 27, 2024 at 9:43 PM Post #1,338 of 1,375
Feb 28, 2024 at 3:53 AM Post #1,339 of 1,375
Unfortunately that does not work.
Dimitri said, that this is a "limitation" imposed by Android.
This problem has been known for a long time. I was hoping that a solution has been found by now.
Feb 28, 2024 at 4:35 AM Post #1,340 of 1,375
Neutron never starts for me when connecting BT
Feb 28, 2024 at 5:36 AM Post #1,341 of 1,375
Funny, for me it starts in my car, but not on wireless headphones - go figure :wink:
Feb 28, 2024 at 6:06 AM Post #1,342 of 1,375
You think its got something to do with android auto?
Feb 28, 2024 at 6:11 AM Post #1,343 of 1,375
Feb 28, 2024 at 7:43 PM Post #1,345 of 1,375
Why do I have the impression that having "oversampling all the way up + dsd 128" makes the top end more enjoyable than "bit perfect + follow source frequency" option, which sounds more peaky and harss to me.
I mainly use a Moondrop S8 + Shanling M7 combo, do someone share the same thoughts or have an opinion on this?
May be my placebo, but I feel that I can hear the difference.
Feb 28, 2024 at 11:34 PM Post #1,346 of 1,375
maybe your ears evolved?
Mar 3, 2024 at 11:37 PM Post #1,347 of 1,375
Heads-up, do NOT install 2.23.7, it's got an irritating bug at the moment with 'trial expired' notification.
I followed the 'complex' set of steps laid out in the FAQ (uninstalled neutron, relocated remnant NeutronMP folder in storage, cleared data/cache from both play store and play services, uninstalled updates for play store and play services, allowed them to re-update on their own, rebooted device, reinstalled neutron from the play store, opened neutron from its play store page). Immediately met with trial expired notification.
Mar 3, 2024 at 11:55 PM Post #1,348 of 1,375
Alas I was too late in reading this and installed the update. It just force closes the app before one gets to do anything.
Mar 4, 2024 at 12:58 AM Post #1,350 of 1,375
Wow just updated then saw the post. Mine does the same thing. Hopefully they'll fix it quickly. Doyeeee!!
https://www.mediafire.com/file_premium/dkdwakzkzmhx2y7/NeutronMP_ARM64.apk/file
I just mirrored the 2.23....4-6 apk (generic, arm64) if ya'll need it in the interim.
-edit- if anyone needs a different apk just reply back and I'll do the same
