Almost all Android smartphones these days support aptX (iOS only does SBC and AAC), but as said, aptX is kind of the minimum standard these days. You will get better SQ with aptX-HD and most noticeably LDAC. Of course, you still need both your source as well as the headphone supporting the BT codec.
I think you may be misunderstanding what you are doing here. Wireless headphones receive a digital signal (via Bluetooth). The DAC is in the headphones. You do not need an additional DAC. There is no part for an additional DAC to play here.
What is the source of whatever you want to listen to?
You would need a device which would digitise the output of your TT2, compress it using a Bluetooth CODEC and send it to the headphone. The latter would then decompress the Bluetooth signal and perform digital to analogue conversion on it before amplifying it so that you can here it.
The chain you propose would sound like any cheap DAP (e.g. Shanling M0) taking a USB feed (e.g. from your Auralic) and transmitting it via Bluetooth to your headphones.
The M-Scaler and TT2 would play no part in the resulting sound quality.
what you are asking is: how can you get the Chord TT2 to fit inside your headphones. Well, not what you were actually asking but in fact what you want... I suggest a good size hammer and vise. Maybe you can make it fit.
So; you're asking the wrong question. Bluetooth headphones are complex devices with a dac built in. Its like a complete stereo system. And therefore will never sound like quality headphones with a cable. You can't beat a cable (yet... it will probably take an extra 20 years or so).
ok
I know, those Bluetooth headsets can look tempting and have cool features (like active noise canceling). So much that I almost bought a pair against my better judgment. But i read (and heard) time and time again that the best wireless of any kind just reach mid-fi compared to regular. That might be the coolest thing for Apple sponsors, but I rather have the best quality for medium prices than the Apple way.
