geremy
- Jan 8, 2009
So is it 1 report from QQQ or 'numerous' reports you site in your original post?
Originally Posted by geremy /img/forum/go_quote.gif So is it 1 report from QQQ or 'numerous' reports you site in your original post? |
Originally Posted by Bullseye /img/forum/go_quote.gif stop listening to your headphones and LISTEN TO YOUR MUSIC |
Originally Posted by m0ofassa /img/forum/go_quote.gif No they arent. Not to mention they are high quality, but they also output relatively low amounts of bass compared to the rest of the spectrum so the driver will move less per average loudness across the spectrum and are typically listenned to at lower bass volumes (main cause of driver movement/blowout). Thanks for playing. |
Originally Posted by MaZa /img/forum/go_quote.gif To cause driver damage you have to blast your headphones on deafening volume and preferably underamplified so that clipping occurs. And this applies to EVERY headphone, not just Grados |
Originally Posted by cactus_farmer /img/forum/go_quote.gif But, would an iPod be considered 'underamplified' relative to Grado headphones in this scenario? I know Grado's have high sensitivity and low impedance, but would the iPod still underamplify them? |
Originally Posted by cactus_farmer /img/forum/go_quote.gif I've read numerous reports of the 'grattle' (Grado rattle) that happens when Grado cans have one (or both) of the membranes of their drivers creased and wrinkled in places - causing rattling on low bass notes and channel imbalance. Does this creasing and wrinkling occur only when the cans are blasted at monstrous levels, or does it happen even at just higher-than-average listening volumes? How loud do you have to drive your cans in order to actually damage them, and is it likely that anyone with normal hearing would listen at that level normally without knowing he/she was damaging their headphones? |
