FiGuY1017
Sq seems worse after the update. Could just be my ears
Indeed. It's just your ears. The sound is as good as ever.Sq seems worse after the update. Could just be my ears
Yes after further listening last night the magic returned to my Ed5Indeed. It's just your ears. The sound is as good as ever.
Once you turn on line out, turn the volume knob until you see line out in the middle of the screen. Press the line out on the screen to enable it.Hey guys!
New owner of an Alpha and I'm very impressed with the SQ when comparing it to my DX314!
I have a question.
I don't know if I'm doing something wrong when trying Line Out?
I have it on low gain, but when I turn on line out, nothing really happens. The volume is still adjustable. Only in the volume screen it says line out. Is this normal? I don't see the point of using the line out function lol. In the settings I have it at the max 2V option. I will try again today but I wanted to ask.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
LOL thanks a bunch!!! Now that I know that, it is indeed a great safety function. And I'm glad it was just me not knowing and it's not a glitchOnce you turn on line out, turn the volume knob until you see line out in the middle of the screen. Press the line out on the screen to enable it.
The extra step is to prevent accidently turning on line out with headphones on.
Alpha is an excellent SQ player. Test mid gain with headphones and IEMs. I always prefer medium gain because of the extra body the music takes on. It would be very good if you could share a comparison with DX314 here.Hey guys!
I have a question.
I definitely will!Alpha is an excellent SQ player. Test mid gain with headphones and IEMs. I always prefer medium gain because of the extra body the music takes on. It would be very good if you could share a comparison with DX314 here.
The battery will take a hit with medium and high gain, but it's something you definitely want to do.I definitely will!
So far my work week has been crazy so I haven't had much time to compare. And the little while I did, was only in low gain. I'll definitely give mid gain a try. Hopefully the battery does not take a hit compared to low?
I’m very tempted to get one! But I can’t chose between Cayin n6ii, Ibasso dx260, and Kann Alpha. I’m looking for an analitycal, slightly warm (deep bass) headphone. Any advice?Been testing the Kann Alpha a few days and I'm very happy with it. It's so liberating to have only my music and not have to worry about android draining the battery. Not needing to leave the DAP on Airplane mode for worrying about the connections impacting the battery.
By the way... this combo, with this song pictured... the bass is surreal.
Yes, Kann ALPHA, high gain, minimum phase fast roll off DAC filter, EQ off, balanced cable, copper cable paired with ZMF Atrium Open or silver cable paired with ZMF Aeolus.I’m very tempted to get one! But I can’t chose between Cayin n6ii, Ibasso dx260, and Kann Alpha. I’m looking for an analitycal, slightly warm (deep bass) headphone. Any advice?
