Ok, so I'm having regular problems in editing my m3u playlist. I don't always want to add new music to the end of my playlist, so would rather edit them. I use Notepad++ and make sure that the line endings are correct and that the encoding is correct (UTF-8). I copy the playlist file out of the SE100 and insert the new files, making sure the path is the same as the others.
Whenever I copy the file back to the SE100, the entire file is wiped to 0 songs.
Playlist as created on SE100:
Playlist edited to be copied back to SE100:
If I copy the first file back to the device, it also gets zapped to 0 songs.
I'm mounting the SE100 using MTP. What am I doing wrong here?
