- Mar 20, 2010
No. The DTS decoder literally converts the DTS signal to Dolby Digital and then to Dolby Headphone. Dolby Headphone only accepts Dolby Digital or Pro Logic II.
Youre not getting a better signal with the Su-DH1. Couldn't hear a lick of difference between the SU-DH1 processing DTS into DH or straight DD into DH.
The only time the SU-DH1 is better is when you play Blu-Rays that only have DTS. However, the PS3 has a bitstream - mix option that converts or finds the Dolby signal in Blu-rays, so the DTS decoding isn't necessary. However if you need DTS decoding for another system, thats when the SU-DH1 is worthwhile. Not that it matters, as its very rare to find... almost impossible.
