I have tried a few eq settings posted from this thread. Audio from the laptop still sounds much worse than with the cipher cable. Which is why I am looking into improving my portable setup so I am not chained down to only using the cipher cable when I am away from home.
Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
- Thread starter Madcat207
dpwolfordMD
- May 3, 2017
Would a portable dac/amp be a worthwhile purchase to use with the isine 10? I almost exclusively use these on the go with my laptop and iphone w/ cipher cable. The laptop on-board sound is pretty lackluster. Would an iFi nano iDSD Black Label or a similar product be a significant enough upgrade to justify a purchase?
I have the isine10’s with cipher that I use when on walks by my apt or if i’m just going to read a book and plug in on my iphone. I’ve tried the isines on my black label and they sounded nice and full with the xbass switch, but honestly when i’m at home i’d rather be using a full size headphone on it.
Then I use the new $100 iBasso IEMs with the $30 Xtremepro USB DAC which is essentially the old 1.2 Dragonfly DAC for my portable setup on my laptop when at work or coffee shops. very nice bang for the buck setup. Minimal setup required and not cumbersome to wear.
kukkurovaca
- Apr 7, 2017
If you don't already have a decent DAP or dac/amp setup, and you want to have options other than the cipher cable, then yeah, go for it.
Although if you're happy with the cipher cable's performance but just don't want to drain your phone's battery while you're working on your laptop, another option is to get a dongle like Belkin sells that's basically a lightning splitter, letting you connect the cipher cable and a charging cable at the same time.
(FWIW I use my iSine 20 mainly with a Shanling M3s and an ALO CDM (balanced in both cases).)
anyworld1209
Hey guys. Is there any parametric EQ android app that has system-wide effect? I'm using Dp-x1a and the native music app doesnt seems to have a parametric EQ ..
areek
I guess only system wide parametric eq system is Viper4android which requires rooting. I am using Neutron music player which sounds great, has p.eq option, but the UI is complex.
Carabei
- Nov 29, 2007
Regarding the question about using DAC with iSines, it’s definitely worth to try. I use iSine 20 with Mojo and EqAPO and Audeze plug-in and it is definitely step up from Cipher cable. Dragonfly Red would be also good if you are on budget.
guido
- Jul 3, 2003
any more comparisons between V1 and V2 Cipher cables?
I will probably sell the V1 since I have no need for a spare cable...
deanderson
- Feb 6, 2014
Just received iSine10 and after about an hour of listening through the cipher cable, I can say these are, overall, just as good if not better than any headphone I’ve owned:
DITA Truth
1more Quad
Alphadogs
Audio technica w1000
Akg k701
Some other iems in the 200-400 range that I can’t think of
Initial impressions (I’m no pro):
Wide open sound stage, similar to the akg, but not as tinny, because of a deep and smooth, yet realistic bass extension, and rolled off highs (there sounds like they put in an artificial cap here, but it doesn’t bother me).
Detail retrieval is excellent throughout the entire range, although obviously sq could be improved from a purely technical perspective.
The bass is what stands out to me: thick, deep, but liquid smooth - I’ve never heard this before, but that must be what people are always raving about with audeze (only have demod the lcd 2 and honestly wasn’t that impressed, but it wasn’t for very long).
Mids are nice and imo well placed (although for some I think they could sound slightly recessed).
Really shines with laid pack, non offensive music, but no slouch in hip hop
The main thing I love is how everything just flows together, and no effort needs to be put in to “make the sound make sense”. Very coherent.
Those are my thoughts
Edit: one thing I would add is that rock does sound slightly muddled, if listening to the Mars Volta. May be the band though.
DITA Truth
1more Quad
Alphadogs
Akg k701
eldss
- Feb 5, 2015
I'd argue that the iSine 20s w/ cipher or well amped are better than most iems under $1,500.
jmotyka
I'd argue the iSine LX is 90% of the isine10 in terms of performance and is by far the single best bang for buck in ear(I own both). I've spent years buying IEM's from Sony, 1more, DUNU, Shure, Noble, and many others including Chi-Fi models and Audeze I think has something special here. I once owned a unicorn Audeze LCD2 and OMG I loved them(why did I sell them facepalm). I will eventually purchase and LCD2C when I can afford to.
deanderson
- Feb 6, 2014
I believe itI'd argue that the iSine 20s w/ cipher or well amped are better than most iems under $1,500.
Palpatine79
- Mar 16, 2017
Soon V1 and V2 on i10.any more comparisons between V1 and V2 Cipher cables?
deanderson
- Feb 6, 2014
What tips do you use?I'd argue that the iSine 20s w/ cipher or well amped are better than most iems under $1,500.
Phil Townsend
im not happy with the case for the 10 and 20’s. They will not work unless you remove the earclips. So, has anyone found a good leather/hard shell case that fits?
Thanks
Phil
Thanks
Phil
I use hard cover camera cases for most of my gear. Purchased from either Best Buy or Amazon.im not happy with the case for the 10 and 20’s. They will not work unless you remove the earclips. So, has anyone found a good leather/hard shell case that fits?
Thanks
Phil
