jlbrach
- Jun 4, 2005
also shows you how good the lcd-4's that they are based upon are!
If you used then on a plane the person beside you wouldn't hear anything above the plane's noise. The other day I took off my HD800S and walked into ther kirchen. I could still hear the hd800s from the other room. So I got out my LCDi4 and put it on the same song at the same volume and i had to put my ear almost on top of them to hear anything. Isolation in that direction is pretty good. But I still. wouldn't recommend them for a plane because of the nature of plane noise. Leaking in (unless you want to listen at uncomfortable levels) When i'm on a plane I don't listen to music, just podcasts, etc and that's what I have Bose for. I never listen to music on Bose but they're the best on a plane.
I agree with that. I was actually trying to say the same thing. If you're going to only buy one iem and you're going to be using that same Iem on planes, I wouldn't buy the i4. I don't even use it next to an air conditioner.
Are closed backs advisable for flights instead? Examples being the Focal Elegia or Stellia?
Is this the new BT cable Jude mentioned in the CanJam London video or is it something else?
https://www.bhphotovideo.com/c/prod...e_cbl_bt_1010_lcdi4_bluetooth_cable_with.html
Jude, how loud would you say the cable makes the i4? Curious.That looks like the one. I ordered mine right from Audeze's web store.
Does the Bluetooth cable work with the Audeze EQ app?That looks like the one. I ordered mine right from Audeze's web store.
nope.Does the Bluetooth cable work with the Audeze EQ app?
