Okay just tried my Sony NW-WM1ZM2 and LCD-i4.. They sound pretty holographic. I'm going to have to get a new balanced cable for them.. This Effect Audio Cable I bought second hand has a defect.Haven't tried my LCD-i4's with my Sony NW-WM1ZM2 yet... No time like the present... I almost bought an M9+... Sounds like I should still pick one up.
Audeze LCD i4 TOTL In-Ear Monitor Discussion
- Thread starter Emerald Core
Yeah, I imagine that would be pretty spectacular! The power of these DAPs accommodate the heavy EQ which turn LCDi4 into TOTL transducer that it isOkay just tried my Sony NW-WM1ZM2 and LCD-i4.. They sound pretty holographic. I'm going to have to get a new balanced cable for them.. This Effect Audio Cable I bought second hand has a defect.
Reading your comments I ended up buying Hiby R6pro2 which has the same chip, so hopefully will be similar sounding. Impressions to follow.Yeah, I imagine that would be pretty spectacular! The power of these DAPs accommodate the heavy EQ which turn LCDi4 into TOTL transducer that it is
Yep just right @ 85/120 on the Sony NW-WM1ZM2 volume wise. Just a little salty about definitely needing a new cable for my i4's.Yeah, I imagine that would be pretty spectacular! The power of these DAPs accommodate the heavy EQ which turn LCDi4 into TOTL transducer that it is
- Mar 12, 2009
How is it?Reading your comments I ended up buying Hiby R6pro2 which has the same chip, so hopefully will be similar sounding. Impressions to follow.
How is it?
Injured thumb so couldn't share impressions earlier.
It is definitely an acquired taste, but totally worth. Hiby's MSEB allows for exploring many genres in a unique way with LCDi4. Not like plug and play, at least for me.
The r6pro2 is extremely resolving and clean for sure, maybe even analytical out of the box, which initially caught me off guard as I expected it to be just a bit warmer. I had to do the manual fine tuning work of finding EQ for a few of the genres, but the more I played with MSEB, the more I was rewarded.
Battery life is short and it is not exactly portable but those are not major concerns for me. I'm so glad I took the leap as now I actively keep an hour aside every now and then to tinker and enjoy what new worlds of sound it could unlock for me.
Hans Zimmer on this combination is stellar and my wife who generally isn't into audio was raving all about how good it makes the LCDi4 (and the Dune score). And so does my U12Ts.
No doubt that LCDi4 requires a lot of power in order to EQ it to TOTL SQ.Injured thumb so couldn't share impressions earlier.
I am finally enjoying what this "iem" can really produce portably driving it with the Shanling M9+. Till now, it has been relegated to my desktop rig.
So happy to take this incredible "iem" on a walk now! Added bonus that you can hear what's happening around you. Corresponding negative is that you'll look like a Sci Fi nerd wearing these in public
You must be a Star Wars fan to wear TIE fighters in publicNo doubt that LCDi4 requires a lot of power in order to EQ it to TOTL SQ.
RPKwan
- Oct 17, 2015
Ken G
Are you able to switch the audio to the correct ear with ifi included software/app if there is one?Good news. IFi GoPods work very well with these. Just need to reverse, right for left and left for right.
ozz007
- Mar 2, 2012
I guess this will fix the ambient mode issue lolGood news. IFi GoPods work very well with these. Just need to reverse, right for left and left for right.
I had XINHS (aliexpress) make it for me. I had him make it with the Eagle CS series conductor (specifically the blue tinted one). The conductor he has available is a little thicker in gauge so the cable is a lot thicker. Here is a link to the actual manufacturer https://www.aliexpress.us/item/2252...t_main.17.36521802ldXQMV&gatewayAdapt=glo2usa, I actually had them make me a cable as well.The cable looks gorgeous.. from where you them ?
RPKwan
- Oct 17, 2015
I don't think so...Are you able to switch the audio to the correct ear with ifi included software/app if there is one?
makan
- Feb 16, 2015
Anyone try the cipher lightning cable with a usb-c adapter on an iPhone 15 to see if it works with the audeze eq? I just got an iPhone 15 from work and wanted to see if I should hunt down an adapter as the iPhone is usb-c now
bneiderman
- Sep 5, 2009
Doesn’t work with app. Works for sound.
Total: 6 (members: 1, guests: 5)
