Jthompson300
Mobius has its own DAC and amp and operates balanced internally.
Yes, I was more concerned about whether or not I could get the Kann to work with the Mobius via USB and needed to use a 2.5mm TRRS but that option is a no go it seems. The problem with the Astell & Kern Kann is that it is not very easy to get the audio out of the USB Micro port for some reason, in fact I have yet to find anything that works with it so my hopes are low that it will work with the Mobius. If anything at least it will be cheap to test it with something from Amazon and then I can figure out where to go from there if it does work in terms of cable length etc. Thanks for the heads up about the USB cable info!
