Audio-gd R2R DAC Thread
thedesigner2011
I'm also thinking about getting the R2R2 and C2 stack, definitely interested in others' comparisons and impressions.
Jimster480
Take a look at soekris first I would say.
Mr G
- Mar 23, 2011
I was about to purchase R2R 2 to pair up with my NFB-1 amp (balanced), and I was informed by Audio Gd that they would be launching R2R 1 (balanced) next week. Cool. I'll be waiting for the new launch. For those with NFB-1 amp, you have another interesting option.
Certain companies would benefit from such transparency,not mentioning any names but you certainly wont see them in Valhalla.
Choosy
Formerly known as terriblenewby
- Nov 3, 2011
Hello There
I have 2 Pi2 unit, I use both for parellel listening in flaw way since some time so I'm pretty sure the unit are working.
I'm used to use RUNE the more because I like the sound, but I use also Volumio and Daphile
I bought recently the new R2R and i started testing yesterday, everything is ok using windows or daphile, when using Raspy I recive a redundant message "audio device is changed" on Rune while with Volumio system alt without particular other signs
I'm starting to think is an HW issue, anyhow I have changed USB cable, Unit, memory card just to skip surprises and I have also changed the way I power raspberry (Using a multiUSB unit and the Samsning note 3 USB charger)
I wrote Kingwa to understand is something may be changed with Amanero interface, I had in fact to re-install driver on window
No idea now about how to go on, a bit frustrated ....Ideas ?
Kind Regards
Alex
Kind Regards
Alex
With the balanced R2R 2 coming out, it'll be a tough decision for me. I was thinking about getting the NFB28.38 as it is an AIO balanced in and out. But for probably the same amount of money I can get the R2R 2. I know I still have to get a balanced amp, but I won't mind doing that if sonically the R2R 2 + a decent balanced amp is superior to the NFB 28.38. Has anybody had a chance to listen to the 2 setup and compare?
Jimster480
The 28.38 isn't actually balanced.With the balanced R2R 2 coming out, it'll be a tough decision for me. I was thinking about getting the NFB28.38 as it is an AIO balanced in and out. But for properly the same amount of money I can get the R2R 2. I know I still have to get a balanced amp, but I won't mind doing that if sonically the R2R 2 + a decent balanced amp is superior to the NFB 28.38. Has anybody had a chance to listen to the 2 setup and compare?
Its a single chip just with a balanced output.
not a true dual-mono balanced output like any other brand would consider.
Honestly balanced doesn't sound any better, the only SQ difference is when you are using dual chips in mono mode, they have more resolution overall.
Thanks for letting me know that. I didn't realize that before but now it totally makes sense.
Mr G
- Mar 23, 2011
R2R 1 balanced DAC has been launched. I plan to use it with my NFB-1 AMP. I'm wondering what is the best connection between R2R 1 DAC and the NFB-1 AMP, i.e balanced connection or acss connection. I'm currently using DAC 19 > ACSS > NFB-1 AMP > HD800S. To my ears this combo sounds great. There is something special about the acss connection (possibly due to current drive?). I would greatly appreciate any advice on this issue. Tks.
Jimster480
Its just current driving as if its on the same board.R2R 1 balanced DAC has been launched. I plan to use it with my NFB-1 AMP. I'm wondering what is the best connection between R2R 1 DAC and the NFB-1 AMP, i.e balanced connection or acss connection. I'm currently using DAC 19 > ACSS > NFB-1 AMP > HD800S. To my ears this combo sounds great. There is something special about the acss connection (possibly due to current drive?). I would greatly appreciate any advice on this issue. Tks.
Basically any internal DAC/Amp will have the same connection.
Mr G
- Mar 23, 2011
Noted. Tks.
Jimster480
Its amazing that the new R2R-1 is balanced but only costs $60 more than the R2R-2?
JaMo
- Feb 8, 2011
Based on what...?! Regarding Your earlier logics...
enjoy
Jimster480
enjoy
I'm not sure your question... it has literally double the number of modules but it costs only $60 more?
Furthering my point about the prices on these units not making sense.
Clearly Kingwa is feeling the competition so he needs to put out better offerings at a better deal.
Total: 6 (members: 0, guests: 6)
