I do have the original ath-msr7. I was going off the specs but I agree now that you put it that way. Me saying “they’re better” was subjective. It’s boils down to personal preference. Maybe I should have bought a pair before posting. ThanksThe tuning has changed. balance of mids and treble has shifted with acoustic changes and driver changes. 'Better' is subjective, on their thread there are owners who strongly preferred the original, YMMV
Audio-Technica ATH-MSR7 Discussion Thread
- Thread starter yellowbirdfly
cpu235
Hi, I am looking for a slightly used or new Yaxi pads and headband cover for MSR7, if you want to sell them feel free to send me a pm! Thanks.
What would be an open full size alternative to the MSR7 up to 1k?
Superprecise microdynamics and macrodynamics (=rocksolid timing, lively sound)???
Great for low volume listening?
Light weight?
Neutral to bright like Grado, B&O?
Matching dac/amp with great PRAT?
Light weight?
tolis626
I was ready to suggest the Audeze LCD-X, but you lost me at light weight.What would be an open full size alternative to the MSR7 up to 1k?
Light weight?
One headphone with similar characteristics to the MSR7 but, honestly, better is the Beyerdynamic DT1990. It's an excellent headphone, but tends more to neutral sound rather than bright. Not terribly light though, but also not Audeze heavy. You might also want to look at Focal's lineup. It's been a while since I've listened to any of them, but they are excellent headphones. Need to choose the right one, though, as they tend to differ quite significantly in sound characteristics. If memory serves me well, the closest sound signature to the MSR7 is on the Elex, the Drop collab model.
As for DACs and amps, I'm not that well versed and, honestly, I'm the kind of guy that thinks DACs are there for features far more than sound quality, and that you shouldn't notice a good amp in your chain, unless it's not providing enough power. For my headphones I use a Topping D70s (which I find total overkill, but I wanted a balanced DAC with, like, all the inputs) and a Drop+THX AAA 789 and it's honestly been amazing, so I won't be upgrading that unless I have to for some reason.
I have the Grado SR325is which is also has an upper mid boost and sounds a bit more punchy than MSR7. These are very open sounding, image well and very lightweight so should also be an option though you might want to look at the RS2 or higher models. Focal is also great, the Clear MG is as lively sounding, but it has a more neutral and warm character. Both of these complement the MSR7, but they sound quite different, but share a lively sound signature.What would be an open full size alternative to the MSR7 up to 1k?
Light weight?
oopeteroo
- Dec 20, 2011
Anyone know if msr7 headband is replaceable ? Is it easy ? Mine start to crumbling real bad.
And where to buy it in Europe ?
Same for the ear pads.
brainwavecoherence
I've got the same issue. Flaking vinyl on the headband and both earcups, and also two bad cables. I have the ATH-MSR7/ ATH-MSR7 LTD. The problem with these headphones is they have a proprietary cable. If you plug in a cable from another headphone, with the same 3.5 mm jack, one channel will not work. They came out with a version B that will accept any cable with 3.5 mm jacks.
So, on eBay and also Amazon there are ads for replacement cables, ear cups, and headbands but I have not taken the risk to order any of these items. As far as the new ear cups and headband, I do not know how well they will fit or what is entailed in stripping off the old to put on the new. I'm afraid of ordering cables that don't work and having the hassle of returning them.
If you order a new headband and/or earcups please let us know how it worked out.
bru87tr
- May 21, 2016
My MSR7’s with the SE cable takes my other generic cables. My Oppo cable works in it too.
bru87tr
- May 21, 2016
I was thinking of trying this. Just not sure if it would fit. Looks like it would.Anyone know if msr7 headband is replaceable ? Is it easy ? Mine start to crumbling real bad.
Dekoni Audio Headband Replacement for Beyerdynamic DT Series Headphones (Choice Leather) https://a.co/d/5vPyJNk
Also, I did try this one and it works, but it was a tight fit.
Geekria Protein Leather Headband Pad Compatible with Beyerdynamic DT990PRO, DT990, DT880, DT860 Headphone Replacement Headband/Headband Cushion/Replacement Pad Repair Parts (Black) https://a.co/d/3vZX8hE
brainwavecoherence
I had a pair of ThinkSound cans, and the cable from these doesn't work and the AT's. Too bad, they are nice cables and much better made than the Audio Technica cables. Customer Support for Audio Technica said, regarding the proprietary cables:My MSR7’s with the SE cable takes my other generic cables. My Oppo cable works in it too.
"We did take on this user feedback after the release of these headphones, however, and understood that customers were wishing to upgrade the cables further and this would be beneficial for the headphones, rather than detrimental, so last year we re-released the headphones as the ATH-MSR7b which now features A2DC connectors to enable our customers to change the cables at will, to ones that suit the quality of the headphones and the requirements of the user.
At this time, I cannot guarantee whether there are any headphone cables that will fit the ATH-MSR7 headphones other than those provided - some high quality manufacturers may be willing to provide a connector to their headphones that would be suitable for fitting into the headphones, but at this time I'm unaware of any alternative cables that are directly compatible with the headphones."
Rodmunch
I'm in the US, but maybe this info is helpful to you.Anyone know if msr7 headband is replaceable ? Is it easy ? Mine start to crumbling real bad.
I asked AT about this and the cost was very high, around $200 IIRC. I bought one of the Geekria headband covers on Amazon and have been happy with it. https://www.amazon.com/gp/product/B07GDQ9QVZ
You can still buy pads directly from AT for a reasonable cost.
bru87tr
- May 21, 2016
Or Amazon.
Audio-Technica HP-EP Replacement Earpads for M-Series Headphones,Black https://a.co/d/2f9n3fi
ferez
- Dec 26, 2011
any cable that has thin enough plastic part below the TRS pin will fit, i am using some random cable that a friend gave me and came from some Marley headphones.I had a pair of ThinkSound cans, and the cable from these doesn't work and the AT's. Too bad, they are nice cables and much better made than the Audio Technica cables. Customer Support for Audio Technica said, regarding the proprietary cables:
i also have another basic black cable which i shaved a mm or two of the black plastic with a knife, and it fits perfectly.
fot the headband just patienly peel all the fragmented pieces of fake leather, and youll be left with a smooth plush fabric, good enough for me
