MattTCG
- Jan 22, 2012
Question, the fit on my NHC has become somewhat "loose" fitting. Is it possible to bend the top frame for a tighter fit?
You can add a rubber band on the headband.Question, the fit on my NHC has become somewhat "loose" fitting. Is it possible to bend the top frame for a tighter fit?
if you are handy with the needle you can consider rebuilding the headband and replace the elastic band inside...Question, the fit on my NHC has become somewhat "loose" fitting. Is it possible to bend the top frame for a tighter fit?
Dekoni makes them. Check their website.Anyone know where one can get new pads for these? I really like the cloth/alcantara? pads more than the protein leather. I just know they won't last forever.
Nice plan. I was looking at these before wondering if they could be used...Got one of these Hifiman Ananda headbands off Aliexpress for cheap. Planning on modding this to replace the current disintegrating headband on the Nightowl
That looks nice!Nice plan. I was looking at these before wondering if they could be used...
https://customcans.co.uk/shop/product/hifiman-edition-xs-comfort-headband-strap-diy-mod/
Interesting. Let us know how it works.That looks nice!
I was prepared to make a mess of things and didn't want to spend too much. Plus they're cheap enough I can always order another one if I botch the first piece.
I finally disassembled the headstrap and it was a LOT easier than I thought. This part below is made from a slightly rubbery material, and flexes easily for the t-shaped retention pins to pop off with a twist.Interesting. Let us know how it works.
