Aune M1P
Mar 21, 2024 at 1:10 AM Post #376 of 482
artists > albums
the only things i dont like about the aune are
-the limited character numbers, meaning i had to rename (shorten) some tracknames to make them show up, and
-the lack of playlists. especially when favourites is limited to 400 tracks (and doesnt work for me anymore anyway weirdly - no one else confirmed this was the case for them)
would have been perfect with those, oh and better battery life
Mar 21, 2024 at 1:15 AM Post #377 of 482
I still have a problem with my SD Card. The 3rd time since Nov 23 I had to format the card. It is a 1TB Samsung SD-card. I thought a good one. But please give me an advice, if you use another one without any problems.
i use an integral 256gb card with no issues. well on 1.074 i had many issues with it both freezing or not reading the card at all. i downgraded to 1.07 (the version on the aune site) and its been rock solid
on the sd card i have the files like this
sd card > artist (folder) > albums (folder) > tracks (files)
Mar 21, 2024 at 5:17 AM Post #378 of 482
Efficiency all the way.
How is the Synergy between the AR5000 and M1P ? I recently got the AR and Loving it and thinking about getting the M1P.
Mar 22, 2024 at 2:38 PM Post #379 of 482
I just wanted to tell you, that my M1P again couldn't read my sd-card. I formatted it and copied my whole library in it... for the 3rd time. After that I put it in my player, started it and listened to the first song. Then I skipped to the next song and everything started again. The player couldn't read the card.
I remembered someone here in the forum, that he downgraded the firmware. I put 1.65 on another SD-card and formatted the DAP. After that I put it my "old" card with my library on it... and guess what? Everything works now. So to everyone who has problems with the SD-card... go back to 1.65.
@AuneAudio Perhaps you could fix this problem with a new firmware update? I was on the most recent one.
Thank you
Mar 22, 2024 at 5:19 PM Post #380 of 482
Thank you
Hi,
me faced on latest one during listening song in flac, device reboot and sd-card scan after. Not sure why.
Mar 25, 2024 at 2:26 AM Post #382 of 482
Thank you
Hi, by "the most recent one" did you mean 1.075 or 1.07?
aune For music we design. Stay updated on aune at their sponsor profile on Head-Fi.
https://www.facebook.com/auneaudioofficial https://twitter.com/auneaudio https://www.instagram.com/auneaudio http://www.auneaudio.com sales@auneaudio.com
Mar 25, 2024 at 11:32 AM Post #384 of 482
Hi.
1.075. I don’t have 1.07 anymore. But I would like to test it too. Where can I get it?
It is me again. I’m relaxing in Egypt right now and my card is not readable… again. I really thought a SanDisk is a good card. So either the card is bad or the player. The only thing I can say is that no other dap before had problems with my card. So I would try 1.07 if I can get it. otherwise I will sell the player.
Mar 25, 2024 at 2:13 PM Post #385 of 482
Mar 25, 2024 at 3:01 PM Post #386 of 482
@Blanka79
1.07 is on their website
http://en.auneaudio.com/uploads/20240124/2b1b3d44cdfe398cfd872e3bcff66036.zip
1.075 caused me nothing but non reads and freezing. get rid of it quick
also list of firmwares here
http://en.auneaudio.com/Portables_en.html
1.07 solved my problems, if not maybe you have a bad card or needs formatting. thats happened with me and a sony 306 where my player kept resetting the library. a full format fixed it.
Thank you @cliffjnr
I formatted 4 times. But I will try 1.07 when I’m at home. I really like the player. I hope it works.
Mar 26, 2024 at 8:12 AM Post #388 of 482
How do you sort your music on your sd card? I am always looking for improvements.
Thank you :)
Genres and sub-genres specific folders and Artists inside of them and Albums under artists. That way I can navigate faster the file manager in offline DAPs like M1p and DTR1+
Mar 26, 2024 at 8:15 AM Post #389 of 482
you might have a dodgy player init. or a card type it doesn't like. who knows
Maybe a card type that the device doesn't like.
I've a similar issue with my M1p, It reads every SD-Card I have except 1. I really don't know the reason behind it. It is just not working in this DAP and working flawless in my other DAPs
Mar 26, 2024 at 8:17 AM Post #390 of 482
Aune M1p rocks with Penon Quattro. Good Dynamics between them
