TMRaven
- Apr 6, 2011
Don't lower the mids on the itunes eq down below -7 or -8db. Things get dark real fast. A good 6db reduction at most should be good for a basshead type bassboost.
What do you mean by the phrase, "match treble level"? I'm sorry, but could you elaborate further, as I am a little confused. Thanks.
I mean that as literally matching the volume so that treble on the LCD-2 sounds about the same as treble on the XB. And just treble, not the average level of mid + bass + treble.
to be honest, i own the xb500, xb1000, ath pro700mk2's and the xb1000 and i can honestly say in terms of just pure sub bass, the xb1000's blow the other 3 right out of the water, and thats with minimal eq
their bass signature is not too disimilar from the lcd-2's rev 2, the lcd2's might be a bit better in terms of layering and texture, but you have to actively search for it, i dont analyze my music, when i listen to subbass oriented dubstep like phaelah, synkro or burial, i just want to enjoy what im hearing period, and i want to feel it
in this regard the xb1000's reign supreme... but ONLY in sub bass, the lcd-2's present the entire spectrum of frequencies beautifully, strong articulated bass, forward, lush creamy mids, and relatively detailed but sibilant or sharp smooth highs
i honestly dont think i would recommend them however at the 1000 price, but since i only paid 650 shipped with an already upgraded cable the value of which was over 200 alone, i can DEFINITELY say i'm more than pleased with my purchase lol
never heard any ultrasone cans so cant comment, but from what i gathered from your posts, the xb1000's would most do you justice, also feel i need to add, even tho i've never heard the xb700's, alot of people claim its sound isnt that different from the 1000's so it might be worth skipping the 500's for those and getting your feet wet with the 700's, the pads on the 500's arent completely circaumaural and at least the top half of your ears will rest on them as opposed to nesting comfortably inside them, just my 2 cents
equipment used was my grant fidelity tube dac 11, running vintage rca mullard made tubes into the jds labs o2 amp and also tried them biased matrix m stage (they're a great match for the sony's, not so much with the lcd's)
But which out of the LCD-2 and XB1000 delivers a stronger and deeper bass if you were to EQ the bass of the LCD-2 to XB1000 levels? In other words, give the LCD-2 a 20db bass boost from 200hz downwards.
I found the xb1000 to be excessively muddy and having less sub bass than my dt770s. I couldn't return them fast enough.
if we're just talking about bass and nothing else, im still going with the xb1000's, its just the nature of closed cans, the lcd's are open and give you really impressive bass for an open can, but its still an open can against a closed one.
like i mentioned before the presentation in the lower hz's are really similar, they both dig down deep, (down to 2hz with the xb1000, is that even sound anymore?! lol) but the xb1000's can be had for $250-300 new while the lcd2's are pretty much 4x that but not giving you 4x the bass, not even 1.5x the bass
as far as eq'ing 20db of bass on the lcd's, you probably can and really be happy with that sound, but you can also do the same with the xb1000's and go even further beyond that, again i cant stress this enough, in terms of just pure sub bass, the xb1000's trump the lcd2's when you factor in the price to performance ratios, now if youre talking about the entire musical spectrum, mids and highs, the lcd2's start to live up their fame and you begin to see where the hype comes from
