tiagopinto
Why are some people so resistant to the idea that there are some minor physical changes as a headphone driver wears in? I can't think of any other mechanical device that doesn't experience some sort of physical change after prolonged usage. Mechanical things wear in, aka are broken in, and then wear out after much use. Regarding headphones, I've noticed that the only ones that I notice a minor, yet still audible difference in are ones that use drivers with more traditional speaker like surrounds.
That all being said, "brain burn in" is also very real. Like in most other things in life, it isn't all of one, and none of the other. Few things are truly binary. There is definitely brain burn in, and also some physical burn in. The magnitude of the effect on sound of physical burn in seems to have some correlation to the type of driver used, and to the materials that a driver is composed of.
And no, I don't have extensive scientific data to back these statements up, or a tidy scientific study that I can hyperlink to. These are just my views, which were shaped by knowledge and logic, and reenforced by experience. Although I will admit that my ability to be so open minded about the concept of physical burn in was helped along by my being given the opportunity to compare my "burned in" example of the P9 to a freshly unboxed one back in 2017, and the same with my Elegia about 2 years ago.
Exactly. Thanks.
