Chris_Himself
Member of the Trade: HPL Audio Cables
- Jun 6, 2007
I'm considering a balanced cable for myself because I'm considering making the dive to balanced drive since I'm in the market for a desktop amp. I'd need to know this to convert all my grados too
It would go:
Modded X-fi optical out>Little Dot Mk7 Balanced> 2x 3-pin XLR (WHERE DO THE GROUND WIRES GO???)> hot/cold leads to Cardas HPSC connectors>HD-580
So far my current setup is a 4 wire braided 28AWG silver cable to 3.5mm Neutrik and it's wrapped in paracord.
How would one even begin? From what I understand it's your standard 4 connector cable, each side has a hot end and a cold end, but now you have a ground... but where does that third wire end up going? I don't use shielded cable, so.... these would just kinda float around in my six wire braid and pick up any external interference like magic?
It's not soldered to the "foil" that cable companies use for EMI shielding right? That'd just create an antenna if anything...
I'd be making a balanced XLR to 1/4" TRS Neutrik and I understand how that would work, just not from the other end of things.
Thanks in advance
Chris
It would go:
Thanks in advance
Chris
