Olimoronio
- Oct 7, 2009
What about tube amps? I have an old tube amp, preamp, and radio that I pulled from a busted up console that sounds really nice - a lot like my McIntosh C220 and NOS Valves VRD's in PP mode but without the guts of course.
I would love to make this into a headphone amp. Would a setup like this work for tubes?
I know if you use too high an impedance with speakers on the wrong tap it can cause serious problems but would this be the same with headphones?
A slightly more elaborate scheme is to use two resistors as a voltage divider across each channel. Here, the output impedance of the amplifier is lower (essentially the resistance of the two resistors in parallel) and the output voltage is less dependent on the impedance of the headphones. Although the effective output impedance is lower, the amplifier itself sees the voltage divider as a series load (which is good). Begin with R2 = 10 ohms (1/2W) and scale R2 up or down to adjust volume. |
