but power (assuming you are speaking about dB/volume) is not something to worry about with HA-3A, never used volume knob above 50%, normally 25% is loud enough... and I'm using RCAs, if you use XLR interlinks to XLR output (there are 3 gain modes), probably there is no headphones that can't be driven to full potential with this ampThe Envy seems to be more powerful (from what I read).
Cayin HA-3A, a Compact 6V6s Transformer-coupled Tube Amplifier
- Thread starter Andykong
Listened a few hours today to the HE1000 stealth and I have to say there is an improvement in SQ vs my 12AU7 Raytheon, but not a step change as I've experienced with with ZMF AO. I have to say, that I find the HE1000 Stealth is such a great HP, they are really versatile and easy to find synergies, they play well in all my devices.Has anyone used E80Cc with HE1000 Stealth, bit concerned they may be a bit too much. Also a bit concerned about the long term stress on the amp. Currently I am more than happy running the Gold lion tubes, very detailed, wide stage, just curious if I can push the sound to even greater heights
So, I never heard the gold lion (but people speak highly abou it), but I would keep it and wouldn't move to E80CC... unless you find some at a good price and in that case you can always re-sell them.
Hope it helps you
mudguardiain
Very helpful thanks. I have to admit I am blown away by the Gold Lion’s currently, great 3D soundstage. Seems to work well with the HE1000. I did try some Apos Ray tubes that were very good but too sparkly for my HE1000, did not sound natural to me. I have some Reflektor 6V6 which are nice but the Gold Lions are cleaner and more open. I will just get on and enjoy my music for now.Listened a few hours today to the HE1000 stealth and I have to say there is improvement in SQ vs my 12AU7 Raytheon, but not a step a change as I've experienced with with ZMF AO. I have to say that I find the HE1000 Stealth is such a great HP, they are really versatile and easy to find synergies, they play well in all my devices.
Hope it helps you
Hohenheimsenberg
I had the 6v6 goood lion paired to tungsram e80cc and the sound was harsh, didn't liked it. TheHas anyone ever compared the Genalex Gold Lions with NOS tubes. I really like the Gold Lions, very hard to pick any fault with them, detailed, very good bass texture, good bass impact & pretty balanced across the range, maybe slightly dark but that suits myHE1000. Just curious to know if any NOS tubes could make a worthwhile difference. I have read several reviews where users stated the Gold Lion’s were better than a lot of their NOS tubes.
Also tried them to the stock harmonix and it was ok, haven't tried the harmonix with other NOS tough, so I can't tell how it modified the sound.
I might try that in the next days.
You have my attention sir.I have some Reflektor 6V6 which are nice but the Gold Lions are cleaner and more open.
Gold Lions on order pronto...
Ultron 5
Thank you.but power (assuming you are speaking about dB/volume) is not something to worry about with HA-3A, never used volume knob above 50%, normally 25% is loud enough... and I'm using RCAs, if you use XLR interlinks to XLR output (there are 3 gain modes), probably there is no headphones that can't be driven to full potential with this amp
mudguardiain
Hope you enjoy them. Give them 20-30 hours to settle in. Will be interesting to see what you think of them.You have my attention sir.
Is there any kind of amp that would share performance quality with ha-3a being headamp and preamp (for speakers) at once?
Check this one: Cayin Jazz 80 - EL34Is there any kind of amp that would share performance quality with ha-3a being headamp and preamp (for speakers) at once?
Jazz is integrated amp, isn't it?Cayin Jazz 80 - EL34
Yes… just chevk if is powerful enough to drive your speakersJazz is integrated amp, isn't it?
https://en.cayin.cn/features/8/57/161/609.html
Well, I said I need preamp to my speakers(not power amp) as is use powered monitors.your speakers
I guess you already considered Feliks Envy?Well, I said I need preamp to my speakers(not power amp) as is use powered monitors.
Not really, it's far beyond my budget at this momentI guess you already considered Feliks Envy?
For me tooNot really, it's far beyond my budget at this moment
I just haven’t heard of other tube amps with preamp out.
There is another option: using 4,4 to 2 XLR cable.
