Thank you!
Cayin N6ii, Unlimited Possibilities: a fully modularized smart DAP
- Thread starter Andykong
May I know anyone have same issue for Tidal playback?
There was an unexpected error. Try again later.
(-1:3:4003)
Just found this error on Cayin N6II, just found the same error for playing some Max quality songs (Not all songs but seems some 24/48 or higher will trigger this error)
I can sure that's Tidal problem as those song played well before I update it
Both my ROG Phone 7 and N6II running the same version of Tidal : 2.110.0.1180.15 and ROG Phone playing those song without any problem
(-1:3:4003)
Are there any workaround for apple music & tidal?
I have been a long time apple music user and soon I realize I use it on n6ii anymore, I sign up free trial for tidal and get the same error as ReikaC’s.
MarkParity
For Tidal you could install USB Audio Player Pro and add your account info into the Tidal streaming section. Offline playback isn't available but it should stream OK. Perhaps try before you buy as I don't use Tidal with UAPP so I have no idea if it will actually work.Are there any workaround for apple music & tidal?
Apple Music, nope that one is a non-starter unless Apple make changes, unlikely I suspect.
Thanks a lot! I will have a try with USB audio player proFor Tidal you could install USB Audio Player Pro and add your account info into the Tidal streaming section. Offline playback isn't available but it should stream OK. Perhaps try before you buy as I don't use Tidal with UAPP so I have no idea if it will actually work.
Even the older version of Apple Music has stopped playing, dang !
Total: 14 (members: 0, guests: 14)
