mikaelmark
- Sep 24, 2011
I know; there are some already written pages about this, but here is how I´m doing it and my experiences:
First of all, I just bought a pair of used AKG K702 in mint condition. First of all, I took of the cushions and cleaned them in a ultrasound cleander with soap and detergent.
After that, I looked around at the web for a good affordable cable for them, and thought of a DIY Moon Cable Blue Dragon V3, as it seem´s to be a nice cable. But because I live in Sweden, the shipment should be around $40.
I also read that the OP OCC Nucleotide made from DHC was a very good cable. One tester claimed that this cable was the only one he tested that gave the phones more base and body. Altough it was Sennheiser, I think it will have the same affect at any phones, and I believe AKG K702 will benefit from this.
So I found this site: www.zombie-x.com/zxamateurcablesrev2/
I immediately get responce and was very accomodating and gime me a very nice proposition at a bargain, so I can solder the phono plus for myself and the wire´s directly to the can´s!
So meanwhile waiting for my cable´s (I also bought a second cable for my portable rig AKG K530), I this week was preparing my AKG K702 for the new Y-cable and unsolder the original cable. It was a little complicated to do; first the grid´s had to be taken off, and I used a pionted plier that I had bent the tips inwards. As you can see at the picture´s, there was some small scratches at the aluminium grid, that I cover with some paint.
Then, after taking off the two screw´s, I poked with a thin screwdriver inside the plastic cover to bent the locking hook inwards while I bent the cover outwards, and then taking off the two lockers for the headband.
Then I desolder all the wires inside the both can´s (the plastid housing get a bit burned, but as it is at the inside, I don´t think it will either be seen from the outside or have any affect at the sound) Maybe I´m gonna fill in some epoxy, have not decided yet.
I also cutted of the cable gland at the left side, as this will not be used any more with the new cable, and I used a mini-grinder and shaped the cutted off piece to fit in the hole with some epoxy-glue.
So at this time, I´m excited for the cable to arrive (it will take some day´s, because he had to order home more material)
Here are some picture´s i have taken:
I´ll be back (as Schwarzenegger said) with more photos and impressions of the new cable when I have made it burned in and listen pair with my modded Arcam CD192 aswell as my also modded Meier Corda Swing!
/ Mikael
/ Mikael
