How did it sound? Thinking of buying them too!Quick picture of the Tansio Mirai TSMR-3.
Chinese / Asian Brand IEM Info Thread
- Thread starter Brooko
Animagus
Reviewer at Twister6
They sound really good from the start. They come stock with the Switch 2 on ON position. It's the balanced signature according to the manufacturer and I like it. Switching switches 1 & 3 on and off adds a bit of bass or treble. That sounds great too!
The look, fit and finish is great! Even without the added functionality of changing the sound signature(a bit), it's still a very good IEM at $189 with all Knowles drivers. It's one talented guy in college making IEMs and he really knows what he is doing.
Also I really dug the simplistic package also. It's comes in a cardboard box with a hard disk case. In it is the IEM with a couple of really good tips, cleaning tool and a switch changing tool. The focus is on what really matters!
Hope this helps.
stryed
EP10 in the house! Very pretty although I wished it had removable cables. Very comfortable, and well built.
Bass is pretty overwhelming & booming but clarity is there up top. Definitely a huge contrast to the EzAudio D4. Will need further testing as my ears aren't used to this anymore. Very tip dependant like the D4, but I'm going for larger bores for this one. However, due to the short nozzle stubby KZ turbos/whirldwinds don't get a good seal. KZ stock tips is OK but I wish I had longer large bore tips (Large size wide bores gave the best sound but they're too big for me).
Can't wait for the Nicehck blackfriday lucky bad
demo-to
I have it in my ears right now, too. And read Crabbos review at the same time.How did it sound? Thinking of buying them too!
Hear it out of my S9 and M0 with stock cable and spiral dots and with switches all on - 123. This puts out the most natural timbre for me - followed by 103 and 023. Though I wished a very slightly reduced mid bass and instead slightly increased sub bass, too.
I can agree with Crabbos findings on these in general.
What to highlight or to underline?
It has a nice clear and clean presentation.
Instruments sounds almost natural, just almost. E.g. strings are lush but are missing the last 5-10% to be live like in timbre (coming from the clinical base).
Stage and positioning is ok to good. It has natural width and depth but height is a bit too low. I can clearly hear the advantage of the KZ BA10 over the TSMR in this regard.
But this all is criticism on a high level.
It is additionally versatile, of very high production quality and very comfortable.
I think the pricing for the TSMR-3 is realistic and it is a good offer.
I decided not to pull the trigger on the DM6 in favour of the TSMR-3 instead.
Since I don't have the DM6 I would be interested in a direct comparison of these.
Who has both and can give some comparison?
Animagus
Here it out of my S9 and M0 with stock cable and spiral dots and with switches all on - 123. This puts out the most natural timbre for me - followed by 103 and 023. Though I wished a very slightly reduced mid bass and instead slightly increased sub bass, too.
I have both but I just got them. I will need some time as I'm still trying to decide on the best tips for the DM6 before I can take them for a good spin. It's quite tip dependent.
Oh and the 123 position in the TSMR-3 is the 'Mixed tuning with lowest impedance' mode according to Tansio. I had my Macbook on 2(volume) for this mode.
Ahmad313
- Jan 23, 2013
Can you please tell me the vocals quality/positioning and soundstage depth/height on the Kylins , thanks .The Whizzer Kylins are my favourite new toy. I cannot believe how small they are but the sound.....
Slater
they seem tight a little too much behind the ear, at least with my glasses.
I have to see if it's boring as the days go by. I will test with the zsn
Can you loosen the ear hooks with a hair dryer?
TechnoidFR
Je n'ai pas ... Do you see Jackson five. Same but white
Mais après 1h of rest to listen I had no embarrassment. for the hooks it's the same system as for the V20 cable
Slater
Well, the TRN cables can be adjusted with heat from a handheld electric hair dryer. V10, V20, V80, the TRN upgrade cables, BT3, and BT10.
So I imagine the BT20 should be the same way.
TechnoidFR
Surely. I just replace them and it's ok
thanks! I might just go ahead and buy them! interested to know how it go against DM6 and DMGsThey sound really good from the start. They come stock with the Switch 2 on ON position. It's the balanced signature according to the manufacturer and I like it. Switching switches 1 & 3 on and off adds a bit of bass or treble. That sounds great too!
Hope this helps.
Bartig
dondonut
- Jan 6, 2017
I have a great hobby.
On close inspection I see you did not use a ruler; I respect those straight lines and neat blocks.
ScottPilgrim
chickenmoon
Faultless sound. Speaker-like, almost. Definitely an amazing DD. Bass is just right.
I would call this the OnePlus of IEMs.
The Moondrop Kanas Pro, folks.
Probably getting mine tomorrow.
Meanwhile the Whizzer A-HE03 Kylin is out of the cooker and it's good, very very good...
Total: 31 (members: 0, guests: 31)
