masterpfa
- Dec 30, 2014
I don’t have a Hugo/2Go but I do have use of the Mojo/Poly combination so I would imagine the following should work for both in the same way.How are folks getting Spotify into their Hugo/2go combos? The lack of Spotify Connect support continues to be an ongoing irritant and the one thing I don't like about my Hugo2 set up. While I usually use Roon/Tidal/Qobuz, there are lots of Spotify playlists that I want to listen to without having to juggle them over Soundiiz to Tidal.
So I'm curious how those of you who Spotify manage it? Bluetooth? AirPlay? Or do you just resort to a different dongle DAC (as I do)?
I have only found a solution, so far, for Android and that’s an app called ‘HiFy’.
This is advertised as
HiFy: AirPlay+DLNA for Spotify
This creates, as advertised, a DLNA device that can be identified within Spotify, similar to other connected devices and or Chromecast/AirPlay devices
