CHORD ELECTRONICS DAVE
Nov 30, 2018 at 12:35 PM Post #12,631 of 26,000
This comment triggers something I have been wondering about. With the very high quality of the HMS/Dave combo, are you able to hear any difference between CD quality and hi-res files? I can think of a lot of technical arguments why the difference should no longer be audible but I am curious to see what you can hear in practice. Thanks!
I can answer for Blu2 + DAVE (still waiting on my HMS). I can clearly hear a difference between CD (16/44) and high res content in my set up (using test files from 2L and other places).
Whether this is due to decimation issues or 16 vs 24 bit or something else, I can't say. On my infinite list of "to test" items, I want to take some quality high res 24/384 recordings and do an integer decimation to 24/48 and 16/48 and compare through mScaler. That would at least take gross non-integer decimation errors off the table in the test.
Nov 30, 2018 at 12:35 PM Post #12,632 of 26,000
With my Hugo MScaler and Dave I can definitely tell the difference and as long as the downloaded file is a genuine hi res file and not just upscaled by the download site. This is the case even if the hi res version is 48k as against 44.1.
Mind you 44.1 red book is pretty darned good through the MScaler. I also have Blu2 in another system and the same comments apply to that as well.
Nov 30, 2018 at 12:51 PM Post #12,633 of 26,000
Thanks for the quick response, guys. I was rather hoping not to mess with hi-res files any more, partly because I don't trust their provenance. I guess you can at least check by listening, as to whether it is genuine hi-res or seller upscaled.
Nov 30, 2018 at 1:02 PM Post #12,634 of 26,000
FWIW, I'm perfectly happy with lossless TIDAL streaming, and only purchase high res content when I adore the label/recording engineer, and trust the content as actual high res. Redbook through mScaler is astonishingly good.
Nov 30, 2018 at 1:29 PM Post #12,635 of 26,000
Since about 90% of so called Hi Res is either analogue or 44.1 in a High res ‘bucket’ I would stick to RBCD which sounds brilliant through HMS
Nov 30, 2018 at 1:44 PM Post #12,636 of 26,000
Whenever I hear a new classical music album release I really enjoy on Tidal, I would purchase the high-res version. Unfortunately that version is almost always 24/96. While I find for some, the difference between the 24/96 and 16/44 is present but not huge, I do find some other albums to offer a much more dramatic improvement. I don’t know whether that’s related to source music or the conversion from the original 24/96 to 16/44. Regardless one thing I consistent find is that the unfolded MQA 24/96 sounds inferior with DAVE or Blu2+DAVE compared to the 16/44. Either way, I can happily live with the 16/44.
Nov 30, 2018 at 1:52 PM Post #12,637 of 26,000
I cannot hear, on most days, the difference between 16 and 24 bit depths and I am not proud of it. I was hoping for no difference answer for CDs and high res through HMS but... sounds like I have another item on the to do list. hdtracks might not go out of business after all.
Nov 30, 2018 at 1:59 PM Post #12,638 of 26,000
I have a Qobuz Sublime+ subscription which gives healthy discounts on HiRes downloads
Nov 30, 2018 at 2:00 PM Post #12,639 of 26,000
Really? Where do you get that from? I'm not doubting you, just asking.
Nov 30, 2018 at 2:07 PM Post #12,640 of 26,000
And how do you know if a file is genuine hi-res of just upscaled?
Nov 30, 2018 at 2:08 PM Post #12,641 of 26,000
If the original master was mastered either analog or 44.1 how can putting this out at high res in 96/24 file increase the resolution.
Of course if the original is mastered 96/24 then there should be an identifiable increase in sq. But how many albums mastered like this are there for the vast majority of music to which we listen?
Nov 30, 2018 at 2:28 PM Post #12,642 of 26,000
Agreed.
Well I thought you were telling us that 90% sold as Hi Res were in fact just upscaled so according to you then your answer to your own question is 10%. Maybe there needs to be some sort of advertising standard on this.
Nov 30, 2018 at 2:40 PM Post #12,645 of 26,000
A source of good quality music 16 or 24 bit is a site called "Bandcamp". I bought a VNV Nation album "Resonance" in 24/88khz and it sounds magnificent. However unlike the majority of their albums, this one was done with an orchestra. And a lot of older albums by various artists are on this site at 24 bits.
  • Back
