stickboy85
- Apr 1, 2015
Just tried Qutest with InnuOS Zen Mini mk2 server and many of my observations regarding the Qutest have changed. With the Macbook pro running Audirvana I felt slightly detached from the performance/music and the soundstage was a bit flat. I also noticed a lack of dynamics and bass. However with the InnuOS Zen things have changed considerably. The soundstage now has greater width and lots more depth, dynamics and detail have increased substantially. Tonal quality and bass has improved, in particular the bass is now quite muscular. i am running the Qutest into an all valve preamp with a very nice valve line stage and the match seems perfect. The difference between the Macbook and InnuOS is huge which just goes to show you need a good front end feeding the DAC.
Vocals are very palpable and real with a great presence in the room. The Qutest, like DAVE is smooth sounding and very analogue in its presentation with very little remaining to remind you are listening to digital audio. For the money Qutest is very good value as I feel it gives me 75-80% of DAVE. Where it looses out is on soundstage /, depth and micro nuances in the music and the sheer gravity and wallop DAVE can produce in the bottom end. However in my system Qutest gives me as much as I could want and on well mastered material it really delivers the goods.
I use my vinyl rig as a benchmark and honestly Qutest with the InnuOS Zen was such a close match on some recordings I could find very little difference between the two, that is how analogue it sounds. With top end information the Qutest with the Zen now sounds much more detailed. I was astonished switching between the Macbook into Qutest and the InnuOS with a recording of Diane Krall called Temptation, her voice took on massive amounts more of detail and nuances and the dynamics of the recording had a real presence and gravity. The piano had a lot more weight and the whole performance sounded more natural and real as if your were in the room with the performers.
So my opinion of the Qutest has vastly improved just by switching from FBA via the Macbook to an InnuOS server. Just goes to show how important it is to feed your DAC the right material.
I must just add my Chord Qutest had already been run in so i noticed no harshness or a bright top end as some have found. however I am running it through an all valve preamp and Hybrid OTL power amp. Transparency is therefore very high!
Nice update, thanks for sharing.
I'm even more curious as to what the Zen/Zenith would do to the Qutest now!
