miketlse
- May 8, 2016
There is more info in the FAQ in post #3And if i wanna use the coax or toslink input and not the usb input?
Seems like this one is the right no? https://www.dysonaudio.com/collecti...hord-mojo-75-ohm-digital-jumper-trrs-ts-3-5mm
Here are the signal paths for an appropriate Co-Axial cable to connect Fiio X3ii and X5ii DAPs to Mojos Co-Axial digital input:
(pin-out identities based upon these: www.head-fi.org/t/784602/14985#post_12467535 )
IMPORTANT: James (CEO of Fiio) has privately confirmed to me that the above diagram is definitely correct for X3ii, X5ii, and X7
Alternatively, if you wish to use a stereo TRS plug at the Mojo end (instead of the mono TS plug in the above picture, which is really all that is required), then the pin connections would be as follows:
(pin-out identities based upon this: www.head-fi.org/t/784602/18675#post_12651727)
