Connector problems MMCX on Fidue A83
Sep 10, 2016 at 5:21 AM Thread Starter Post #1 of 1
Capt. Z
I finally found some IEM that I can listen to and enjoy music while working outside.
However, the right channel cuts out on and off and I traced it down to a connection issue with the MMCX connector. I have used a contact spray to clean the contacts, but that seems to be only a very brief solution. I also remember reading here somewhere that other people had the same issue with the Fidue A83.
Just wondering if there is a fix to this like fixing the MMCX connector on the existing cable or a new, replacement cable, without spending a 3 digit $ amount.
