IlluminatiTri
Thanks. Good to know I'm not doing something wrong/I don't have a defective unit.No native support of DSD over ASIO. it is DoP only.
Also, one more question I can't find (maybe I'm bad at Google). The Ares supports 24/384, but the XMOS audio driver only lets you output at 24/192. Why bother even saying it supports 384 then if you literally can't do 384?
On Windows, it will only work for me with the XMOS driver, and with that installed, I can only select 24/192. I wonder why it will work on Mac.It supports 384 through Audirvana + for sure - I've tested this many times.
So yes, it does support 384 without any drivers on mac.
What are you able to set output to in Windows playback devices? Also, are you using the XMOS Driver? Just trying to figure out what's wrong for me.Definitely supports 384 on windoze. Tested with foobar, HQP& Roon
I can't use ASIO on JRiver because DSD isn't supported over ASIO, and I do have some DSD stuff that I listen to. I normally have it set to WASAPI so I can play DSD.If you are trying to use the windows playback devices then you may be limited to 192. I have tried both ASIO (Foobar, Roon and HQP) and WASAPI (foobar and Roon), 384 works without any issue.
Since you are using JRiver you shouldn't have an issue as I believe JRiver supports asio and WASAPI.
Ares supports 358.2 & 384 on USB only. I think all the other inputs are capped at 192 KHz
What I'm talking about for 24/192 is this: 1) right click the little speaker in the bottom right of Windows 2) click Playback Devices 3) double-click XMOS Audio (or whatever the Ares is) 4) go to Advanced tab 5) click Default Format dropdown box 6) look at maximum bit depth/sample rate
For me, the max I see is 24/192. What do you see? Or does the Windows setting not actually affect what JRiver can output if JRiver is set to not downsample?
