subwoof3r
I don't remember which ones was the bad (14.8mm) drivers, as I ordered both from same seller :
https://www.aliexpress.com/item/2045541063.html
https://www.aliexpress.com/item/32776696327.html
I did not spend much with those drivers anyway, but I agree that one or the other was sounding much better than the other one.
Can't find the link of the 64 ohm I ordered but I'm pretty sure it was from CKLewis. The only good drivers them that seller that I retained was the 150 ohm, which was my best until I had 130 beryllium
