- Aug 15, 2011
Hi all,
I've done some soldering here and there and built small little interconnects however I'm thinking of making my own headphone cables for my recently acquired Focal Utopia headphones. I've picked up my LEMO connectors and have spare plugs at home already and now looking at cabling.
As it's easy for me to access Oyaide cables, I've been thinking about these :-
1) PFTE +pt AWG26
or
2) PTFE +Alpha AWG26
I would guess solid core wouldn't be worth it if it broke and either of the two options above would do the job. My noob questions are :-
1) would AWG26 suffice 2x channel (total 4 core) or should I look at 4x channel (total 8 core)?
2) How long should I buy? I'm looking at final std 1.3m length headphone cable. Would buying 8m (assume 4 core x2m, budgeting in braiding) be considered excessive?
3) as I've not braided before,
a) should it be tight/loose?
b) up to the Y-split, wrap per channel or wrap all 4 core (or 8 core) into one?
c) is it all worth it?
Apologies for the very basic questions, 'cos as mentioned, I've not built a headphone cable before.
1) PFTE +pt AWG26
or
