skyline889
- Jan 1, 2006
I recently moved my gear around so I now need a longer cable for my monitor. Right now I'm running a VGA cable but since I need a new cable, I figured I might as well upgrade to DVI at the same time. I'm not really looking for something high end, just something to ge the signal from A to B so I figured a DVI cable like this (http://cgi.ebay.com/15FT-DVI-D-DUAL-...QQcmdZViewItem) would be fine for me and still an upgrade compared to the stock VGA cable I'm using right now.
The thing is that the price is almost the same for the 10ft and the 15ft versions so I would like to purchase the 15ft version as it will allow me more flexibility in the future but I also understand that there is a certain length restriction for DVI cables. So my question is whether or not I will see a performance degradation when comparing the 10 and 15ft lengths, should the 15 ft be ok? Or should I just get the 10? Thanks in advance!
