Sharpenologist
Neutron... I haven't tried playlists with Mango yet...Are you using Mango or Neutron? Do you have shuffle mode enabled?
And shuffle is off.
Thanks again!
Are you starting the playlist from the top level playlists section in Neutron? When you tap the playlist name, are the songs displayed in order? How are you starting the playlist (tapping on the first song or the play icon at the bottom)?Neutron... I haven't tried playlists with Mango yet...
And shuffle is off.
Thanks again!
Hello, I want to buy a dap and I have two choices, Fiio x7 gen 2 + AM3D (module with THX technology) and iBasso dx200, both new for 700 euros. What do you recommend? Recently I returned a Fiio M11 Pro on the grounds that it has some too hot environments and the scene too in front, not being a big fan of this type of sound. X7 gen 2 I listened to it and liked it, but I didn't listen to dx200. I want a more neutral sound, without being bright. I don't know if it matters, but I use Dunu from 2000j, which can be a little aggressive if they don't match the source.
DX200 sounds alot better than fiio x7mk2. fiio x7mk2 tuning is terrible sounds ... not that good.it has terrible support. When I used to own one had issues with lineout port. but worst of all is its sound. To me it just sounded wrong in every regard(imaging,soundstage, general sound reproduction is not that great cause of the strange sound tuning they have done the middle channel seems huge and sides are small and near by. While with ibasso dx200 sounds are reproduced correctly and sounstage is huge,with incredible imaging/detail, and the tuning is fantastic it surrounds you with music from all sides.Hello, I want to buy a dap and I have two choices, Fiio x7 gen 2 + AM3D (module with THX technology) and iBasso dx200, both new for 700 euros. What do you recommend? Recently I returned a Fiio M11 Pro on the grounds that it has some too hot environments and the scene too in front, not being a big fan of this type of sound. X7 gen 2 I listened to it and liked it, but I didn't listen to dx200. I want a more neutral sound, without being bright. I don't know if it matters, but I use Dunu from 2000j, which can be a little aggressive if they don't match the source.
I think you could be good with M11 Pro, if you had different earphones. IMO, earphones are the most critical component. I have CA Solaris, and with these even my Fiio BTR3 sounds awesome And as a DAP I have the DX208, but I don't use it a lot these days after I got the BTR3, which is much more convenient, and when on the go, the sound difference is barely noticeable.Hello, I want to buy a dap and I have two choices, Fiio x7 gen 2 + AM3D (module with THX technology) and iBasso dx200, both new for 700 euros. What do you recommend? Recently I returned a Fiio M11 Pro on the grounds that it has some too hot environments and the scene too in front, not being a big fan of this type of sound. X7 gen 2 I listened to it and liked it, but I didn't listen to dx200. I want a more neutral sound, without being bright. I don't know if it matters, but I use Dunu from 2000j, which can be a little aggressive if they don't match the source.
Totally agree, I only wanted to say that one can't appreciate a DAP in full with subpar earphones, and that, IMO, oftentimes a change of headphones gives a better growth in sound than a change of a DAP. I also read your post above and it's basically about the same as my postInteresting point - The reason I use a 'Reference' DAP is because I usually listen at home to reference quality quality with high quality headphones as that is the quality of listening that I am looking for.
If you are looking for a DAP that you will be using more for 'out and about' then you could probably go a lot cheaper
Really depends on what your needs are
I would say though that IMO every component in ones audio chain is important as every part plays a part - If even one of those parts is lacking then what you hear in the end will be less than ideal / or as good as it potentially good be
That is exactly what I was going to say next!. To my ears the amp1/dx200 combo is dreadful and baffled me when I first heard it. In fact I was very suspicious of iBasso business model when I first heard it wondering if they knew that people would have to upgrade to make the player sound as good as it needed! Once I bought amp5 I was very happy though. Im sure teh X7 will be fine but I do think that long term the quality of the DX200 + a descent amp is right up there with the best of themThanks for the answers. I stayed and thought, I think I will choose X7 gen 2 with the THX module. Dx200 with AMP1 has a sound too "flat" for my tastes so I should buy an AMP5 or AMDP9 module, that is +200 euros. I will use the dap when I am gone, I have two headphone systems at home so iBasso would prove to be too expensive for my needs. Going back to the Fiio M11 Pro, I listened to it with Dunu in 2000j, Dunu Titan 1 (I like Dunu sound) and open headphones (90s model) Akg K500. I didn't like the sound, so I don't think if I listened to it with other headphones it would have been another situation. It reminded me of the Caiyn N6 first-gen sound, which I didn't like again.
