Thanks, will try, Tidal was recently updated when I checked version.I had this issue several months ago when Tidal updated. No sound.
Easily remedied though. Just download an older version (around 2.27.2-999 or older) and make sure you don't update it.
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
Sorry, it’s been a while since I used Android, do I need to uninstall current Tidal first and lose existing downloads? I have Play installed, can that download other than current version, or do I remember getting an APK file from PC download or direct to DX200? Thanks.
edit- ignore that, realised need to search for that versions APK, installed, works again!
thanks very much for help
heliosphann
Awesome! Glad I could help.Sorry, it’s been a while since I used Android, do I need to uninstall current Tidal first and lose existing downloads? I have Play installed, can that download other than current version, or do I remember getting an APK file from PC download or direct to DX200? Thanks.
parabellum777
Thanks for the solution. I was getting crazy trying to make Tidal work fine, but it seems that since version 2.27 the updates cause problems with DX200.I had this issue several months ago when Tidal updated. No sound.
gimmeshelter
I'm needing a new battery for my DX200, could you please help with this @Paul - iBasso ?
Hey Mate. Not sure if you are looking to replace the battery yourself. You can pick one up here: https://www.aliexpress.com/i/4000534450668.htmlI'm needing a new battery for my DX200, could you please help with this @Paul - iBasso ?
gimmeshelter
Perfect thanks mateHey Mate. Not sure if you are looking to replace the battery yourself. You can pick one up here: https://www.aliexpress.com/i/4000534450668.html
Dobrescu George
Reviewer: AudiophileHeaven
Batt replacement is super easy and fun on iBasso DAPs
IT IS HEAVEN
I broke my smartphone the previous weekend, replacing anything on a smartphone is NOT FUN.
So I'm thankful for how iBasso made things with their DAPs
IT IS HEAVEN
- Oct 14, 2013
Yeah, exactly ! That keeps it running for many years to come, just so long as there are batteries for itBatt replacement is super easy and fun on iBasso DAPs
IT IS HEAVEN
ehjie
- Apr 7, 2009
You can email Paul. I ordered one from ali, not a very good experience.I'm needing a new battery for my DX200, could you please help with this @Paul - iBasso ?
And they're not expensive (original Ibasso)...
raymondkerr
I am new to DAPs and got myself a DX200. I stream using Apple Music and download to listen offline. I use the internal 64gb storage, if I install an SD card, can this be used to download more Apple Music content to listen offline ? or is it just for storing and listening to your own music files ? I only use it in android mode, because I don't have my 'own' music files, mango isn't of much use to me at this time.
jon parker
an SD card can be used exactly like an external hard driveI am new to DAPs and got myself a DX200. I stream using Apple Music and download to listen offline. I use the internal 64gb storage, if I install an SD card, can this be used to download more Apple Music content to listen offline ? or is it just for storing and listening to your own music files ? I only use it in android mode, because I don't have my 'own' music files, mango isn't of much use to me at this time.
With the greatest respect though, playing higher quality audio or DSD will really allow the DX200 to shine and show you all it can offer
ehjie
- Apr 7, 2009
Yes. I don't store files on the internal storage.I am new to DAPs and got myself a DX200. I stream using Apple Music and download to listen offline. I use the internal 64gb storage, if I install an SD card, can this be used to download more Apple Music content to listen offline ?
All your DL apple Music files, you can try to play it back in the Mango, maybe you can hear sound improvements...or is it just for storing and listening to your own music files ? I only use it in android mode, because I don't have my 'own' music files, mango isn't of much use to me at this time.
dkalgray
Have had a DX-200 for a few years now. A few things I’d like to share. Firstly, I’ve tried a number of different headphones with the DAP and the best match (under A$2000, closed back) I’ve discovered is the Beyerdynamic AK TP-5 Gen 2. I’ve tried (and owned) numerous different headphones and iems (including Shire KSE1200, Audeze LCD-X, Fostex TH-600 and several Focal headphones) but the Beyers just sound great without any need to EQ. Second, I use Fidelizer Purist ROM and run the player in dedicated Mango mode (sounds better than Android IMO). Third, I’m using the Amp1 Mk2 and I recently had Fidelizer do the Signature H/W update which has also improved the DAP sound (maybe 15-20% better, but this is a bit subjective, the bass is definitely better and the mids and upper frequencies seem to have opened up a bit as well- only had the updated amp for a few weeks so possibly could get better after more burn in??). Was going to sell the DX-200 as I have other more expensive gear that sounds better, but for a mid priced DAP and Headphone combination that I’m happy to take out and about, it’s hard to beat.
Themilkman46290
So what sounds better? I tried the kann and didn't really like it, also tried cayin and fiio's higher end and can't say it was betterHave had a DX-200 for a few years now. A few things I’d like to share. Firstly, I’ve tried a number of different headphones with the DAP and the best match (under A$2000, closed back) I’ve discovered is the Beyerdynamic AK TP-5 Gen 2. I’ve tried (and owned) numerous different headphones and iems (including Shire KSE1200, Audeze LCD-X, Fostex TH-600 and several Focal headphones) but the Beyers just sound great without any need to EQ. Second, I use Fidelizer Purist ROM and run the player in dedicated Mango mode (sounds better than Android IMO). Third, I’m using the Amp1 Mk2 and I recently had Fidelizer do the Signature H/W update which has also improved the DAP sound (maybe 15-20% better, but this is a bit subjective, the bass is definitely better and the mids and upper frequencies seem to have opened up a bit as well- only had the updated amp for a few weeks so possibly could get better after more burn in??). Was going to sell the DX-200 as I have other more expensive gear that sounds better, but for a mid priced DAP and Headphone combination that I’m happy to take out and about, it’s hard to beat.
And I am curious, does anything really sound better at around a similar msrp? Or do I need to save up a small used car payment ($2000-3000) to do better sound quality wise?
