Luke Skywalker
Tried a full reset and just put Tidal and Qobuz on. Still having all kinds of problems getting screen to come on. Really wishing I’d opted for the A&K
What is going on with your unit ? We need a more detailed lay out to give any helpTried a full reset and just put Tidal and Qobuz on. Still having all kinds of problems getting screen to come on. Really wishing I’d opted for the A&K
screen not turning on? try to just disable double tap to wake completely.Tried a full reset and just put Tidal and Qobuz on. Still having all kinds of problems getting screen to come on. Really wishing I’d opted for the A&K
They are afraid that they will have to pay for additional damages ?I had that issue on a DX320MAX, randomly couldn't wake the screen pressing power even when music was still playing. Holding power to hard reset would bring the screen back on but obviously reboot the device. The issue went away after performing a full firmware flash with QFIL and the provided image (generally available in the first post of iBasao DAP threads, why don't all manufactures do this ? )
Hmm… didn’t work but thanks for helping mescreen not turning on? try to just disable double tap to wake completely.
Hey thanks for taking the time to help me. It’s pretty baffling truthfully. I’ve done a full reset twice and it’s still happeningWhat is going on with your unit ? We need a more detailed lay out to give any help
Does anyone have an update on resolving this unresponsive power button and blackscreen issue? I paid too much to try figuring out how to get my DAP to do its job. I have had this unit for 2 weeks and about to return this for the inconvenience this unresponsive power button and black screen issue causes when trying to turn on/off the screen or change songs.Hey thanks for taking the time to help me. It’s pretty baffling truthfully. I’ve done a full reset twice and it’s still happening
It’s rather difficult to reproduce. Sometimes I can turn the screen off and on with no issues. Other times it stops working immediately. Sometimes plugging it into power will make it flicker on and off or start working normally.
It drive me crazy bedside I’m in IT and it seems like there’s some kind of pattern that I’m not seeing
One thing is rather consistent. When I keep it plugged in and don’t use it for 10 or 15 minutes the screen almost always stops working
And here is the weirdest part. In almost every case I can press the side play button and listen to music with no issues. In fact it sounds amazing
I did return one to bloom and upgraded it sp3kWell, I did find a solution. My favorite company Bloom let me return mine and after confirming the screen issue, they let me pay the difference to upgrade to an SP3000. It’s amazing
Ugh,Well, I did find a solution. My favorite company Bloom let me return mine and after confirming the screen issue, they let me pay the difference to upgrade to an SP3000. It’s amazing
Don’t think you bricked it. Probably a bad patched boot IMG. Do a QFIL installation of the original firmware, and go from there ?Guys, I tried to root my DX320 and after loading the patched BIN file with QFIL to both Boot A and Boot B in the Partition Menu, my DX320 doesn't to be able to boot normally, whenever I select START or other options it only goes back to the same Menu.
What am I doing wrong?
I can pull up the DX320 into EDL mode on the QFIL whenever I need to so I don't think I bricked the player but something doesn't feel right.
Yep you're right, I redid it again and it works now.Don’t think you bricked it. Probably a bad patched boot IMG. Do a QFIL installation of the original firmware, and go from there ?
In the top left corner that is where the menu isYep you're right, I redid it again and it works now.
One last question........
With the Kernal Manager app,
I don't see an option within CPU that says "CPU sets Audio-Apps CPU to core 4-7"
I already set the frequencies and the Governor settings but I don't see a CPU option specifically regarding Audio.
