MatthewK
My 0404 USB is in the mail (I'll probably receive it Monday or Tuesday). I'm thinking of replacing the power supply with something of a higher quality. I may or may not use the headphone jack on the 0404 USB, but I'll definitely be using the mic preamps.
Here are two threads that talk about replacing the power supply with a linear regulated one:
http://www.head-fi.org/forums/f6/emu...g-help-297141/
http://www.head-fi.org/forums/f6/the...-audio-231867/
Does anyone have any more advice? If I get the power supply from Jameco and the cable with the correct connection, how will I know which wire to solder to which wire? I noticed one of the wires has a white stripe on it, but the other doesn't?
Thanks for any help you guys can give me, I really appreciate it.
