golov17
no, he mean any buds, maybe, like Edifier h190p..What?? Do you mean poweramp the app..??
PowerAmp the App. As I am using PowerAmp to listen to the music, I am feeling that may be the reason why my two earbuds are broken. I wanted to check with you guys as you know much much more and better than me if high impedence earbuds or earphones should only be used with amplified apps or device?
http://powerampapp.com/
Power amp is an app... Music Player. It wont magically amplify your music more than your current device can supply. You will need a proper amp to do that, it wont ruin your earbuds. Unless your listening at very high levels with your iphone 7G.
higher impedance doesn't mean higher quality: shozy stardust is 16 ohms.
I don't listen to really high levels but it is around 60-65% volume as NY Subways are very noisy and u cannot listen to anything at low volume. But I still feel that PowerAmp might be the reason why earbuds are broken.
Whoever has Edifier H185, guys, try that little gem with double thick foam. It becomes a monster (in a good sense)
Poweramp wont break your earbuds, its a music player app. Its like listening any other way to music, portable cd player, mp3 player etc. Your phone is the source/player. So unless they have been mistreated Poweramp wont wreck them.
Did no mistreated them at all. All of a sudden SHE3800 broke down. It still works if the volume is considerably low but as soon as it hits 50%, sound cracks and I listen that noise. One thing I noticed that Sound is really bass boosted and thumping bass in PowerAmp, do you know how that comes and if I want that kind of sound effect in iPad, what needs to to? I used Rockbox but it was not good so reverted back to Apple firmware.
I afraid that the problem comes from diaphragm hits the front plastic cover. Perhaps you need to change the front plastic cover that provides more space so that diaphragm can freely move.
