Okay, so I have two headphones and I would like to compare their audio performance in the most objective and unbiased way possible.
They blatantly feel different on the head, so technically I can't really call my comparison a true ABx test as I can tell X just by feel. Impossible to blind test these headphones.
I am just trying to be as objective about this process as possible. Audio memory is definitely unreliable, so having both pairs of headphones at the moment, I would like to do a direct comparison.
These headphones have different impedance and efficiency, so they playback at different volumes when software volumes are held constant. I know that volume is an important variable to control. It is funny because many comparison reviews around here never try to control for volume, so I was curious what an easy way to do that would be. Seems like all possibilities for volume-matching are quite convoluted and may not be reliable without specialized equipment or preparation, so it is probably impossible for a hobbyist to really do such an experiment...
It is extremely amusing to me that a hobbyist forum dedicated to headphone performance does not have some sort of universal testing system established with volume-matching for comparing the performance differences between headphones.
My conclusion is that probably all impressions/comparisons of headphones made ever around here are probably significantly influenced by lack of volume-matching & probably is not reliable... The fact that most comparisons are not done directly means that our unreliable audio memory also plays a big part in our subjective impressions...
Thank you
@Strangelove424, your suggestion of using a SPL meter app is the the suggestion that sounds most feasible and I will attempt this experiment over the weekend. Thank everyone else for the general information about which frequency response to match.
I guess I can always just write a review based on how I feel with lots of flowery audiophile terms
heh
