I'm fairly certain I've tried "every" tip with EVO and the AEX07 is the clear winner for me. I've gone pretty far down the tip rabbit hole and believe I have every newly-hype'd tip that's out there. Just a few that it beat out...Azla Crystals, Azla short fit (?), Azla Max, Azla xelastec, Whizzer, numerous SpinFits and others I'm not thinking of. Would probably have stopped at Xelastec if they were maintenance-free.
I am thinking about using custom IEMs when I cut grass, which takes 1 to 1.5 hours. I do not want to use my current IEMs for this purpose as I would prefer a less expensive IEM. What would people recommend as lower priced IEMs that have a warmer sound signatures and sound great for the price?
Don’t know about your mower but I have not found any IEM that I can even hear over the sound of the mower, regardless of sound isolation, and have opted just to protect my hearing by using foam earplugs. If you are are sitting on a riding mower with a cab YMMV- anyway IF I was going to try this my rec would be either ER4XR or the Hifiman RE800 silver, which I can insert quite deeply and has good sound isolation too. Good luck and be careful out there!
Within EE, the clear answer is Bravado. On the cheap level you can check the Belos Audio. A bit higher you can go A4s.
On the ANC side, it may create a lot of ear pressure due to the Noise Canceling and music on top. So, I'm actually not a fan of them on really noise places.
Spinfit W1 are not for me. To my ears, it makes the bass thinner, pushes the mids further up and on some tracks it creates an artificial sounding treble. Also makes a smaller soundstage. I'm sticking with the Azla Standard (improves on the Final E).
Thanks for the suggestion. I actually tried the Crystals with my XM4s - by any chance you also have them on your XM4s? If you do, do your Crystal (for TWS) have the same shallow (short stem) as with the Crystals you use on your EE IEMs?
