obobskivich
You are right as I was thinking of USB to the USB input of the dac and not two usd devices running at once. The cable is wrong and doubt the dac would recognize the turntable. Not for sure if the USB output of the turntable is digital or not though. I corrected. I have no problems when I'm wrong .
Technically it is possible to build a "DAC" (that's in quotes because the device would be far more complex than a single digital audio to analog audio converter - it'd really be blurring the lines between PC and hi-fi components) that could act as a host for this, but I'm not aware of any real-world product that supports it. There *are* some USB-based DACs that can run mass storage devices as hosts (so you can plug in a hard drive or a flash drive and read music off it), but that uses more generic drivers/interfaces than the USB audio controller built in to the turntable - if you think about the turntable as being a complete turntable with the analog-in section of something like the Behringer UCA202 (or some other similar device) strapped onto it's outputs, that's basically what you've got, so you'd have to have driver/software support on the "DAC device" side for it to run as the host. Like I said, it'd really be blurring the lines between PC and hi-fi component, and while it's technically possible to do something like that, I'm not aware of anything one could buy on the open market that could do it. Most "USB DACs" these days are a USB soundcard so they also require a host (e.g. a PC; some smartphones and tablets can do this too), with drivers and all that (so-called "driver free" devices rely on generic drivers from Microsoft, Apple, et al) which differs a lot from something that takes AES or S/PDIF. But again, there's nothing that says if a device were designed for this it couldn't work, and frankly I think it'd be a neat direction for consumer electronics to go, given that USB finally has the bandwidth to handle basically any audio (or video for that matter) bitstream one could dream up, and cabling is dirt cheap. We can dream...
