You can save several presetsNice! Does it have multiple EQ slots for saving presets like the RME does? I’m impressed if it can match or exceed the RME.
Eversolo DMP-A6 Network Streamer/DAC
- Thread starter PopZeus
skhan007
Thank you guys- you've been really helpful in guiding my purchase decision. There are very few reasons NOT to buy this unit. I'll download the user manual and see if I can research my other questions.
While I enjoy having my laptop as the central brains of my music, I know it's not optimal because of reasons already discussed (memory, processing, possible jitter, etc.). I believe that with the A6/A8 (whatever I decide), I can listen to my files via SSD and stream. I'm concluding it will stream Spotify until I choose between other streaming options?
I suppose that when I'm browsing for music on-line with BandCamp, YouTube, etc, I could also have my laptop hooked up via USB and listen to those sites. The rest can reside right in the A6.
The A6 seems to be a bit lower in price these days, since the launch of the A6 Master and A8. Decisions!
LucasChahin
Hey friends,
has anyone has tried the Eversolo dmp-a6 to a Singxer su-6 ddc? does improve de streamer sound overall?
Best Regards
Best Regards
easier since not that rich in functionalities. But it is quid--pro-quo!I have the basic DMP-A6 and RME ADI-2. The difference to playing from an iMac with Audirvana is big. PEQ in Eversolo is better and easier than in RME.
What 'user frendly' has to do with the above 3!?Transparency, rendering of space, separation of instruments. Eversolo is more user friendly
TwoNice! Does it have multiple EQ slots for saving presets like the RME does? I’m impressed if it can match or exceed the RME.
More than two. In each slot you have 1 GEQ and 1 PEQ, but there are many slots. I have saved 3 slots so far and I still can save more
martas38
PEQ in Eversolo is easier to set up, has more functions, for example more filters can be used and most importantly it has 10 bands.easier since not that rich in functionalities. But it is quid--pro-quo!
Nope! If you want to improve go for improvement in front or after wifi/modem.Hey friends,
Best Regards
skhan007
Guys- If I connect my blu-ray player (for blu-ray audio only, not movies), will the A6 show me a listing of tracks on the screen? I'd like to not require a tv/monitor, if possible, for blu-ray audio.
jcn3
i don't think so -- how would it be able to recognize the track?
skhan007
No idea. The same it would recognize a CD track when you go to rip/download a CD? Just curious about how to listen to Blu-ray audio, if it's even possible.i don't think so -- how would it be able to recognize the track?
jcn3
When you're using a digital input you're making the dmp-a6 into a dac. Dacs don't look up meta data. CD rippers have built in functionality to retrieve meta data.No idea. The same it would recognize a CD track when you go to rip/download a CD? Just curious about how to listen to Blu-ray audio, if it's even possible.
mks100
Some Blu-ray players have 2 HDMI outputs. One to send the Audio/Video signal (perhaps ARC or eARC) and one to send an Audio only signal. I believe the DMP-A6 is intended to receive the Audio only output of a Blu-ray player. It would work just like a coaxial or optical digital out (no Metadata) BUT would be able to pass DSD (due to encryption rules for SACD). There is no optical drive and/or file reader to read the disc and/or file Metadata and send it to a screen in this instance.No idea. The same it would recognize a CD track when you go to rip/download a CD? Just curious about how to listen to Blu-ray audio, if it's even possible.
DBaldock9
Since it supports an external USB optical drive for CD disc playback and CD ripping (according to the website) - it may also support an external USB connected Blu-ray player.
