Feliks-Audio EUFORIA - A Wolf in "Sheep's" Clothing...
May 5, 2024 at 12:37 PM Post #11,464 of 11,502
The Linal have a nice top end that goes very far, depending on what driver tube you use, it can also go in the romantic direction.
The mids are also super nice in the vocals with nice hihats and full power.
They are definitely better than the Ps vane, anyone who has swapped their Ps Vane for something else will tell you that the Euforia goes in a completely different direction.
The Linlai's with Russian EL34 wingend C from Svetlana from St.Petersburg are also very pleasant.
Everything becomes clearer, more defined, lusher and more powerful and slightly on the warm side with it, which is a good combination.
May 5, 2024 at 12:43 PM Post #11,465 of 11,502
Has anyone tried Linlai's with TungSol 5998 in Euforia?
May 5, 2024 at 12:59 PM Post #11,466 of 11,502
Yes, I found the TS5998 not so special even if they are better than 6080s.
They are open and warm but still neutral enough.
Not bad but I prefer them more in EL34 or KT66/88.
The type of tube really does make a difference.
If you want a good tip, buy EL34/Kt88 Svetlana winged C from the ST.Pertersburg version and use 6V6 tubes as driver tubes and you will be happy.
The 6v6 play even more sensitive and have a better timbre to the instruments.
Especially on Zmf headphones this pairing comes into its own.
Another advantage is that the 6v6s don't draw as much as the 6SN7s, so this pairing sounds very smooth and not distorted in the bass range.
May 5, 2024 at 1:38 PM Post #11,467 of 11,502
I can only agree with that. I found a pair of EL34s from RTF, a bargain at 80€, and they are simply fantastic - I prefer them to my 5998 & KT88/66.
Forgot a pic from the tubes :D
May 5, 2024 at 2:16 PM Post #11,468 of 11,502
Ty for that usefull advice!
Which 6v6 would you recommend?
May 5, 2024 at 4:24 PM Post #11,469 of 11,502
Phew difficult depends on how the output tubes are tuned.
If you have the Rft for example then I would want to add some heat and something that is more rounded like Westinghouse.
The 6v6 range offers a lot, I don't have many myself but it's enough.
Sylvanias are also very good but a bit more neutral.
May 5, 2024 at 4:50 PM Post #11,470 of 11,502
What kind of socket do the 6v6 have? I have adapters for the KT88‘s, do they work?
May 5, 2024 at 5:10 PM Post #11,471 of 11,502
The adapters from @Deyan will definitely work.
I can't say whether the ones on Ebay would also work, you would have to ask the seller on Ebay.
I wouldn't risk buying blindly and simply inserting them.
Maybe someone knows where these are used from Ebay?
Personally I prefer to buy from Deyan because the sockets are of good quality.
And you can always ask Deyan if something is wrong.
May 5, 2024 at 5:51 PM Post #11,472 of 11,502
How would you describe the sound they impart?
May 25, 2024 at 8:53 PM Post #11,473 of 11,502
Solid combination of Sylvania 6sn7gtb 1956 and TS 5998. The prints of the tubes are matching so perfectly that it was worth a picture 📷
No real need for adapter tubes. There are plenty of available native tubes for crazy prices 🤑
May 31, 2024 at 7:58 AM Post #11,474 of 11,502
Hello everyone. I am new to this forum, but the amount of information here is just amazing. Thank you all for sharing your experience.
I have a question about the Bendix 6384 tube. I did not find much in this forum or online about using this tube in the Euforia.
The Bendix 6384 is a 6L6 variant with different pinout than 6L6 and will require an adapter to use.
Did anybody here tried this tube in the Euforia?
Thank you.
Jun 1, 2024 at 6:34 AM Post #11,475 of 11,502
So you're using the same adapter for EL34 that you use for KT88, etc... ? I enquired about EL34 elsewhere and there were concerns about G3 not being addressed/connected by the typical adapters people were using for KT88/6L6. I know KT77 is fine since it's connected internally.
I have the Linlai E-6SN7 and I like them quite a bit. I also like the the Northern Electric 6SN7(made by Full Music I think). Both are better than the PSVane Elites that come with Euphoria AE IMO. Lately I have been using JJ KT88 as output tubes and they are hands down my favorite KT88 so far. I was surprised that they were so much better than the Gold Lion, but then again, I was never a big fan of the GL KT88. Sovtek 6550 of Winged C 6550C run circles around GL KT88. Even the TAD Redbase KT88s are better than GL IMO.
