[FiiO BTR15/BTR5 2021/BTR5]Bluetooth DAC and Headphone Amplifier Discussion & Impressions Thread
Dec 25, 2023 at 7:57 PM Post #3,346 of 3,706
There's an annoying feature / bug in BTR15 I wish @FiiO could fix ASAP. When I turn off the device and put it for charging, it automatically powers back on. IIRC none of the earlier BTR drvices behaved this way. Can we please just have the BTR15 stay off when a charger is connected. TIA.
This doesn't happen on my BTR15. I have had instances though where I thought I already turned it off before plugging it in to charge, and ended up having it stay powered on and connected to my phone the whole time. I believe this was because I was used to the comparatively shorter press and hold time on the power button of my BTR5 to power off.
Are you 100% certain it's turned off before you plug it in?
Dec 25, 2023 at 9:40 PM Post #3,347 of 3,706
Got my btr15 few days ago. I like it so far. Pretty small and convenient.
Anyway, today when i use it, it has low battery and i switch to pc mode while connected to my phone and playing music via tidal. I noticed that my unit turns warm so i stop using it that way. Is that normal?
Dear friend,
When you use BTR15 to connect to a mobile phone, please switch the mode on the side to PHONE mode. We have also recently updated the BTR15 firmware, you can check it out: https://forum.fiio.com/note/showNoteContent.do?id=202312201447233677679&tid=77
Best regards
Dec 25, 2023 at 10:27 PM Post #3,348 of 3,706
Or… do you have the car mode enabled?
Dec 25, 2023 at 10:52 PM Post #3,349 of 3,706
Dear friend,
This problem has been fixed in the latest firmware of BTR15. Please update the firmware of BTR15: https://forum.fiio.com/note/showNoteContent.do?id=202312201447233677679&tid=77
Best regards
Dec 25, 2023 at 10:56 PM Post #3,350 of 3,706
What is the real life battery on the btr15?
Dec 26, 2023 at 1:18 AM Post #3,351 of 3,706
Had my btr15 a couple of weeks. So far it’s been a nice upgrade from btr3k. Using mostly with FH3, but also experimenting with chi-fi iem collection.
Just got update to 2.2 firmware, looks to be a few fixes and extra settings. Unfortunately it seems to have broken saving custom eq’s for me on iOS app (1.2.7), hopefully will get a fix soon. Would be nice if custom eq name was reflected on btr15 settings menu. Also bal boost setting is not persisting.
“2.2
  1. Added the function of changing the self-defined El name on the FIIO Control app;
  2. Added the time option for screen timeout in the menu;
  3. Added the independent volume adjustment among the PC/BT/PHONE mode;
  4. Fixed the issue where the gain level would be out o line if being switched between high and low gains;
  5. Fixed the issue where the charging icon would flas when switching the charging mode from PHONE to PC;
  6. Fixed the issue of inaccurate full charging detectio and battery level display;
  7. Optimized the UAC battery life in the PHONE mode
  8. Miscellaneous improvements in performances.”
Edit: Also in app online feedback form is hanging when I try to submit.
Dear friend,
We have discovered this issue and will fix it the next time we update Fiio Control App (iOS version).
Best regards
Dec 27, 2023 at 12:24 AM Post #3,353 of 3,706
Today while using the btr5, not btr15, I turned on LDAC mode on my samsung tablet, the tablet says streaming LDAC but the btr5 screen shows aptx.
Does the btr5 not support LDAC, I thought it did.
Yes it supports LDAC. If you have the FiiO Control app try and set it at LDAC. Or try forgetting the BT connection and then reconnecting it.
Dec 27, 2023 at 11:27 AM Post #3,355 of 3,706
I have the BTR5, not an issue I have but you can try to hard reset the device and forget device on your tablet. Start fresh and give it another go also check if your app has any specific codec deselected while you're at it. Get back to us if that doesn't fix it 🫶 instructions to hard reset are available online:wink:
Dec 28, 2023 at 7:26 PM Post #3,359 of 3,706
I am not able to add my BTR15 to the Fiio app
Edit. Updated app and now connects no problem
Dec 28, 2023 at 8:33 PM Post #3,360 of 3,706
Hi @FiiO, I've had the BTR15 for about a week now and I'm enjoying the portability.
I use it connected to bluetooth to both my PC and iPhone 14 Pro. Music streaming over bluetooth works well. However the bluetooth sometimes disconnects during a phone call or, on my PC a teams call.
I am on firmware 2.2. Is this a known issue or do I have a faulty device?
Thanks
