snellemin
- Mar 6, 2015
Getting the FH5 soon enough. Curious to hear if the Hype is real.
Thanks for the review Brooko. You mentioned you got the best fit with the Symbio MandarinE Ear tips. Were you using the normal bore or the Wide bore ones?My review of the FiiO FH5 quad driver hybrid IEM is now posted:
https://www.headphone-earphone.reviews/2018/07/23/fiio-fh5-hybrid-iem-review/
For those who have these, is there any driver flex when inserting or using them?
What is "driver flex"?
By saying "driver", do you mean the actual driver hardware inside the IEM?
if you do, which means it will be moved by pressure?
That must be defeat or bad design.Yes, the driver membrane, if not vented properly, will bend and crackle when inserted until the pressure eventually equalizes.
