shutterbox
- Jul 19, 2008
@shutterbox - if you get the chance - drop 2 kH by about 4 dB and 1 kHz by about 2 dB (with EQ) and see if that helps.
If I get the chance, I'd try that out
yes, we have change the mmcx connector from FH5 to get the best connecting. BTW, the mmcx is still a big challenge to us. maybe we will have to change a better connector in the future.
Mmcx's are a tricky connector regarding different cables fitting tight or loose on different iems, the connection of the stock cable is a solid one and nothing wrong if your not going to change or unplug them much but as most mmcx's they will become loose over time due to wear. You can slightly open the ring washer to get a firmer hold ( if your careful ) . We use mmcx's in certain PCBs and power boards in my job but if they get unplugged more than 3 times when we are testing finished units we automatically change for new before shipping to customers due to reliability issues.
Do consider 2-pin in the future. Not ideal, but most people who cable roll have a collection of 2-pin connector cables.
Yes, we also found that the FH5 will benefit from a pure silver cable , that is the interesting part for the user to find !
Depended on our research, most detachable IEM used MMCX connector, and there are too many different kinds of 2-pin connector , so if we don't care about our IEM can use some 3rd party cable. we will design a special connector which only for us.
Please don't do that -- I think most people want the option of changing out cables for another option. Having proprietary connectors might cause me to not buy headphones -- I don't buy ones with non-detachable cables now, and this would be a similar kind of decision.Depended on our research, most detachable IEM used MMCX connector, and there are too many different kinds of 2-pin connector , so if we don't care about our IEM can use some 3rd party cable. we will design a special connector which only for us.
Those look like whirl wind tips.
