I’m curious as to how this compares to the HiByMusic R6 Pro.
[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
rodrigoadbraga
- Jul 25, 2014
Play services and play store?
iscorpio71
Hello,
Hope this DAP does support third party app as Google play music. As the M9 disappointed on that regard.
Best.
IB
Best.
IB
rodrigoadbraga
- Jul 25, 2014
That's the reason that I didn't buy the m9, I have the same hopeHello,
Best.
IB
Probably skip this M11 DAP because i heard one of my local shop (E1 personal Audio) said that he had seen the blueprint of both M11 and M13 not sure whether its true but now kinda believe him due to the fact that M11 lauched, the news i have heard was 4 months ago prior to this post.
jmills8
Previously known as bmiamihk, jmills2
Hello, Im very interested in this " All-new dynamic EQ". EQing is very important when Im using gear on the go. Thanks.
Dear friend,Hello, Im very interested in this " All-new dynamic EQ". EQing is very important when Im using gear on the go. Thanks.
Thank you for the kind interest on our product.
The M11 support 10-band +-12dB dynamic EQ, you could choose your suitable EQ.
Best regards
jmills8
ThanksDear friend,
Best regards
@FiiO will Apple Music install and work on the M11?
Dear friend,@FiiO
It looks great, but fix the standard problems before release, pls pls pls.
* micro gaps
* gapless playback
From our test,there is no gaps when you use FLAC/WAV/APE/AIFF or other lossless music format.
It's micro gaps when you use the MP3 or wma,because there is a blank data in the begining of the file.(Foobar/Rockbox/Hiby Music are the same as FiiO Music)
If what you faced is different from what i described,pls send the file to support@fiio.com.Once we received,we will check it as soon as possible.
Dear friend,Will Apple Music work on the M11?
Apple Music can installed in M11,but it has a problem when you log-in.
We are still talking with Samsung and Apple to find a way to solve it.
D
As M11 support 2.4Ghz/5Ghz WiFi,so you can enjoy the LDAC stablely when you use the 5G WiFi.
Dear friend,As i undestand M11 will be fully capable of playing LDAC at the same time with using WIfi. My m9 can't do this because of processor limitations. So Playing tidal using wifi and LDAC isn't possible as sound is stuttering and stopping.
Also wondering if 4493 will be an upgrade from 4490 used in m9.
Dear friend,Play services and play store?
According to Google Play policy, any device that based on Android 7.0 or higher should get GMS certification to use Google Play service. Unfortunately, Google had shut down the GMS certification channel for versions earlier than Android 9.0, which made it impossible for devices running Android 7.0 or 8.0 to use Google Play service.
It means there is no Play store in M11,but you can download all the free apps on Google play freely from some apps such as APKPure.
Dear friend,Hello,
Best.
IB
M11 is developed on open Android,you can install any apps with no limition.But because there is no google play services in M11,so maybe you can't use the app which based on play sevices.
By the way,you can download all the free apps on Google play freely from some apps such as APKPure.
katatonicone1
Dear friend,
I have zero problems with that. I'm just super happy I can install any app I like. Thanks!
Total: 9 (members: 0, guests: 9)
