Ah cool well not cool but thanks did you manage to get and E.T.A for a patch fix
Juj
No word yet. Eagerly waiting.
Juj
That's a big relief. If fiio knows about the issue and it's firmware it can be possibly fixed in the future. Lol I never kept headphones connected longer than half a second to know that it would eventually stop. When it happened with my BGVP DM7's connected my ears were ringing for a minute or two afterward.
With all the chat of it I was starting to look at a standalone DAC but wallet is in a very deep pocket and I have very short arms , argh!!! the scotsman curse.
Juj
Sure it will be fixed the dacs and CPU are very capable.
I just ended up buying another screen protector to keep mine from sliding in the leather case. The TPU is too slippery for me to stand. Debating just making a leather case myself at this point. Can't stand the corners/top not being protected at all.Might go back that route. Curious if anyone picked up https://www.aliexpress.com/item/33028993533.html and feedback.
Juj
Meanwhile I’m actually flirting with the idea of dx220 FiiO better fix this soon or bring the pro (without this problem) sooner
Thanks for the info. I hope they can offer an update to fix it. Since it can be avoided I'll keep the M11.Ahh welcome to the club
FiiO already told me that there is a firmware issue related to this. It’s not a hum from power or static. It’s a USB high speed serial data traffic coupling into audio path. The only way to stop it is to disconnect the USB cable. It lasts 3-4 seconds at most so you can keep the headphone/iem disconnected for few second after you press play. But if you go into mute state, this will happen again. You can toggle USB DAC mode and USB disk mode, restart PC/M11 to temporarily reduce the chance of happening.
It’s a really unfortunate problem...
I was worried I might have lost my hearing too. Now I keep my IEM away from my ear when I start to play when in suspicious condition.
Definitely could work, I would just want something a little less jank haha.Could you use the tpu as a base to stick the leather or is that too bootleg lol
Juj
