Airsculpture
Hope so, there are features which they could/should implement and fixes required. But who knows.
I was taught “If all else fails, RTFM”Before enforced retirement, I was in the computer industry.
And RTM was an acronym we used, 'Read The Manual' or if it was someone we knew... RTFM. I'll leave you to work out what the F stood for.
Anyone had any issues with ES File Explorer repeatedly crashing upon opening ?
Am I ok to download the app from the Play Store or does the firmware on the M11 use a special version ?
Or any alternatives that would work on the M11 ?
I really don't want to go back to scratch installing fresh firmware and setting up my settings up again - took me best part of a day the last time I was having slowness issues so if I can avoid that, great.
Dear friend,
If the issue still remains, please contact support@fiio.com with the log files attached:
When the certain problem happens on the player, please go to " Settings ->About device" , and continually tap“Model number", until the prompt "Have save output log to built-in storage" appears. Then please wait for about 20 seconds, and go to player's internal storage, then send these two log files "XXX-kernel-xx.log" and "XXX-system-xx.log" to us for further analysis.
Best regards
Thanks for the reply Dud. Which File Manager app as there are loads ?
I think the reveal is planned for May. New design (no volume wheel, glass back very similar to M17), Snapdragon 660 with Android 10, MQA, THX AAA-78. Not sure about DACs but probably ES9038Q2M to compete with M6 21 and R6.Standby, a M11 Plus is coming. Don't know the specs yet.
Yes that would be like having a CD or any source hooked up to a preamp or in your case an Av.I occasionally use a SPDIF cable and feed my Marantz 6012 so not exactly what you are talking about I guess.
