newworld666
FiiO Music App V3.0.9 for M series players update now!
Updated in 2022-01-25
Changes and improvements about new Android APP are as follows :
1. Added a new theme: Technology (can be enabled in Settings -> Theme -> Custom background);
2. Upgraded the BT device control center to a brand new one(now called FiiO Control);
3. Added sorting by year;
4. Added support for DLNA-Emby service in Media Server(Emby/UPNP/SMB protocols are now supported);
5. Added Now Playing list in the Media Server playback menu;
6. Added new options: Max Volume Lock and Allow background Activity (can be set in Settings -> USB output);
7. Fixed the issue where the volume control would not work for some tracks in D2P output mode;
8. Fixed the issue where the DSD tracks might not be played properly (only white noise can be heard) while the Exclusive USB audio access mode is turned off;
9. Miscellaneous improvements on performance;1. Added a new theme: Technology (can be enabled in Settings -> Theme -> Custom background);
4. Added support for DLNA-Emby service in Media Server;
FiiO Music app-V3.0.9 for M series Android players: Click here
How to check the APP version of FiiO Music app:
From settings-About-VersionX.X.X
How to update the FiiO Music app in players:
Set the device to storage mode and connect to computer, drag the downloaded FiiO Music (.apk) to the device. Then disconnect the connection and enter ES file explorer/file manager, find the FiiO Music app in internal storage/sd card and click install.
Do I miss something, or FIIO player access to Upnp servers doesn't allow DSD files to be played on the M17 ?
I have no issue with flac files and with Neutron no issue with Flac "and" DSD files from my Synology Upnp Server.
And it's a pity that Fiio player can't be set as a DLNA renderer to be accessed by an external player like Bubbleupnp, Neutron, Mconnect, Foobar2000 .. for access to Qobuz, or when the M17 is used on the desktop stand connected to a DC 12V/3A plug (not really easy to manipulate) and must be driven by a Windows computer, Iphone, Ipad Pro or any of my android smartphones.
