[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
Apr 30, 2022 at 3:26 AM Post #3,722 of 5,703
What are benefits of this "user account system" function in FiiO music player using M17? 🤔
"2. Your FiiO account is shared across FiiO Music app'" - what does that mean? 🤔
Same Q as Ben.
Apr 30, 2022 at 8:32 AM Post #3,723 of 5,703
Apr 30, 2022 at 11:18 AM Post #3,724 of 5,703
I had few times in Tidal as well, only solution was turning off, no display blinking in my case. Hopefully sistem update will sort it out.
after how many hours of constanst tidal use?
Apr 30, 2022 at 12:25 PM Post #3,726 of 5,703
The FiiO Music App V3.1.0 is coming
I have 3 FiiO DAPS. FiiO music is great but for one thing:
Please add parametric equalization to it. At least 7 bands but 10 would be preferable.
Missing that capability is singularly the ONLY reason I do not use your software on my FiiO DAPs.
Apr 30, 2022 at 12:35 PM Post #3,727 of 5,703
Fiio music app on m17 has superior sonic qualities compared to even Neutron especially in Pure Music mode. This is my preferred method to listen to music.
Burn in update at almost 36 hours playing DSD512 in loop. I plan to let it burn in for 100 hours and see if that eliminates the ever so slight sibilance in some of my library.
Apr 30, 2022 at 12:52 PM Post #3,728 of 5,703
Ever try USB Audio Player Pro? Even just as a payer, not to stream to as an external DAC. I paid money for both. But stopped using Neutron and use UAPP exclusively. I find the sonics in bit-perfect to be a 1:1 with FiiO Music. Slight step down when off when I need a parametric eq.. I paid for the Tone Booster plugin too, which is the best peq I've used.
Apr 30, 2022 at 12:56 PM Post #3,729 of 5,703
I own both and UAPP as a player for local music would be my third choice. 1st is Fiio 2nd would be Neutron and 3rd being UAPP. To my ears UAPP sounds artificially boosted a db or two.
For streaming bit perfect I prefer UAPP as my first choice
Apr 30, 2022 at 2:15 PM Post #3,730 of 5,703
used to do the same via integrated tidal. however, since the native tidal app is able to bypass android standard driver, i just use tidal itself and UAPP for qobuz.
Apr 30, 2022 at 6:11 PM Post #3,732 of 5,703
Any idea why purchased music videos from YouTube won’t play on the M17?
Apr 30, 2022 at 6:29 PM Post #3,733 of 5,703
Never tried qobuz. How is it any different from Tidal?
there are endless discussions regarding both competitors. technically, qobuz is able to deliver double times higher resolution as max.
May 1, 2022 at 4:37 AM Post #3,735 of 5,703
in bit perfect via UAPP for example.
