emilsoft
- Dec 5, 2014
AmazonHi,
Where do you find the USB adapter ?
I know that Ifi power2 have adapters but I would prefer the power X one.
regards
AmazonHi,
regards
Not the Q15 but is the system level PEQ on M15S also available in USB And BT modes, or only on Android?Yes,
Q15 now supports PEQ for Bluetooth input, but we don't have support for coaxial and USB inputs yet because we've encountered some problems during debugging, which are being solved now.
In the future, we will release new firmware, then you can use it normally after upgrading!
Is it possible to know if it will be in the same M15s range or will it be lower or higher??Yes,
we do have a player whose DAC is AK4499EX + AK4191, which is expected to be available in March next year!
This doesn't matter, as long as he supports the standard PD protocol, or the QC3.0 protocol,What if the charger supports more than one standards and works up to 15V?
Let's say: DC 5V/3A, 9V/3A, 12V/3A, 15V/3A ?
Now Only on Andriod,Not the Q15 but is the system level PEQ on M15S also available in USB And BT modes, or only on Android?
I think the question is for non PD supply of 9v - will non PD standard 9v 3A supply be accepted by the device? Or will it cause damage? As it’s not PD, there will be no handshake, it’ll instantly inject 9v into the usb - is this going to be a prob?This doesn't matter, as long as he supports the standard PD protocol, or the QC3.0 protocol,
then the adapter and the Q15 will automatically handshake until both sides agree on a common 9V supply
This won't cause a problem, as long as it doesn't exceed 9V and can be stabilized at 9V, it will workI think the question is for non PD supply of 9v - will non PD standard 9v 3A supply be accepted by the device? Or will it cause damage? As it’s not PD, there will be no handshake, it’ll instantly inject 9v into the usb - is this going to be a prob?
Dear friend,@FiiO the q15 is no more available in black on AliExpress, will it be available again sooner ?
Regards
Eq more bass and eq less trebleWhich filter make more body lush fuller sound which i prefer?
